Results 1 to 2 of 2
Thread: Torque Convertor and Flexplate Seperation.
    Jul 2009
    NH
    I searched and didn't find any info on it so I'll just mention it. Even checked the Ford MM service info manual. If anyone needs to seperate the TC from the flexplate, if you rotate the crank (18mm socket/wrench/a little mucscle) to 0, 90, 180, 270 to the TDC mark on the timing cover, it lines the bolts up perfectly with the service access hole to remove the four 14mm nuts. Engine pull tomorrow! Woohoo!!!
    12.073 @ 118.43 (Nitto 555)
    Drag racers prayer:
    Just a FYI, the OEM converter uses studs & nuts, the aftermarket converters use bolts.
  1. For Sale PI Torque convertor F/S
    By hotford in forum Marauder-specific Parts for Sale
    Last Post: 05-02-2010, 08:53 PM
  2. Torque convertor or OD band failure?
    By derik in forum Transmissions
    Last Post: 04-05-2009, 07:56 AM
  3. Torque Convertor installed
    By Blackened300a in forum Community Discussion
    Last Post: 06-03-2006, 11:19 AM
  4. I'm thinking of getting a torque convertor....
    By StevenJ in forum Shop Talk
    Last Post: 01-30-2006, 11:15 AM
  5. Torque Convertor?
    By BLACK THUNDER in forum Shop Talk
    Last Post: 01-20-2006, 06:56 AM
