Page 1 of 4 1234 LastLast
Results 1 to 15 of 60
Thread: Engine ticking up top,right side, is it time to panic?
    Jan 2017
    Regina, Saskatchewan Canada
    Bought an 03 3 months ago. Wasn't running. Replaced tires,starter,air bags,pcv valve and fuel filter. Changed oil and antifreeze. Removed old fuel from tank and line, removed plugs (looked good) cleaned coil boots and plug wells. Drove it for the 1st time yesterday. Has a noticeable tick at idle coming from the passenger head and timing cover area. Doesn't idle very good at stop lights either but never stalled. Misses intermittently at idle,more so on right bank. Didn't floor it once on test drive but was impressed with how much power it had. Put a 100K on it yesterday to check for any other issues and no error codes yet. It's a Canadian marauder with 170,000 kilometres. Any ideas or suggestions?
    Jun 2012
    Grand Rapids
    Def want a good mechanic to listen to it BEFORE you keep driving it. No destruction has happened yet. You may need timing chains / guides / tensioners replaced. TOW IT to a shop you trust. ONLY RUN IT WHEN YOU HAVE TO... Plenty of people have made the mistake of thinking it will be o.k. and then....
    #2941 300A
    4.10's, carbon clutches
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Bar tender and maker of:
    Christmas in a cup
    One Legged Lesbian Kickboxer
    Cocka Two
    Jan 2017
    Ok thanks for the input. Wish I knew a good automotive mechanic that I trusted. I haven't taken any vehicle I've owned to a shop in 30yrs. Haven't had to do any major engine or trans work on my vehicles since high school. Went to school for heavy duty mechanic in 87 and an instructor told us that a good mech is someone who ( if they screw up while repairing customer's equipment) convinces customer it was their fault and gets them to pay for it. No doubt that's still the case. Been trying to educate myself on this engine for 3 months now. Bought Sean Hyland's book as well. Just looking for more insight on the idiosyncrasies of the 4.6 dohc.
    Thanks to all of you. Great forum
    Jun 2012
    Grand Rapids
    Take a video of it with your phone and post a link...
    #2941 300A
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Christmas in a cup
    Cocka Two
    Jan 2017
    Jan 2017
    Wish I knew how to do that it. Took video but no luck sending GF is workin on it cause I'm not computer savvy at all. I suppose I'm in denial it's obvious what I need to do. Timing chains for sure. Was just super excited to finally get to drive it.
    Nov 2016
    Corvallis, Oregon
    That doesn't sound good.
    you live on a dirt road? does not sound very good, would not drive it.
    Arrow do not run motor
    Does not sound good , running it is likely doing more damage
    SOLD MY MARAUDER .
    Aug 2010
    Winchester MA
    Best case is dropped valve seats and some roller followers have popped out
    2004 Mercury Marauder 300A Black
    Build date: 9/26/03 552 of 3214 2004's
    105K miles Second Owner. Charcoal interior Heated Seats All stock with Lidio 91/93 Octane tune 14.85@95.63 with 93 tune only. 96 cobra intake cams in the cellar, pondering TR6060 swap.
    Pictures
    2004 Crown Vic LX 150K Silver Birch with Light flint leather. Auto dim mirror, EATC and steering wheel radio controls. 21mm marauder rear sway bar and wood steering wheel. MM head unit , MM subwoofer coming (really) 04 P-71 80 mm MAF/ airbox 04 p71 zip tube 04 P-71 PCM swap. Heated mirrors with silver birch endcaps coming!!
    Pictures
    1996 Lincoln Town Car Signature
    Touring Edition 250K 2004 PI 2V swap complete! Sold
    Pictures
    74 Laguna S-3 Project car Original 400 Small block
    Jan 2017
    Yeah I live out in the sticks. Won't drive it till I fix it. Guess I'll do a compression check now to see how the rings and valves are sealing and determine how deep I gotta go. Hope it's just loose chains. Thanks for the help
    That noise is not loose chains .
    SOLD MY MARAUDER .
    Jun 2012
    Grand Rapids
    I'm afraid that is not loose chains... time for a rebuild.
    #2941 300A
    Marty O Tune
    Curless Cure
    Widened Wheels
    Dead Pedal
    Eaton Swapped
    Christmas in a cup
    Cocka Two
    Rockford
    Thumbs up
    free diagnosis
    Apr 2003
    Fairfax VA
    Could the head casting issue be a part of his issue??
  1. Replies: 21
    Last Post: 01-10-2011, 02:08 PM
  2. Engine warm-up time
    By MapleLeafMerc in forum Shop Talk
    Last Post: 01-12-2009, 07:24 PM
  3. Trans Shifts and TC Lockup.....
    Last Post: 02-15-2004, 03:25 PM
  4. The Prowess of the V8 Engine:
    Last Post: 01-15-2004, 03:41 PM
  5. 4.6L 3V VVT Engine
    Last Post: 05-20-2003, 11:27 AM
