Any one recommend a GOOD rebuilder for my '68 LTD's C6?? Other areas??
TP 703 280-7164
TP 703 280-7164
Pat Smiar In Columbus Indiana! Best Ford Transmission guy in the country!Originally Posted by Thomas C Potter
Thanx, I assume he is listed in Columbus info phone service??Originally Posted by marauderhombre
He should be!, if not, let me know, and I will find it!Originally Posted by Thomas C Potter
Their's a Tranny Forum that might just help you find someone closer to you.
www.network54.com/forum/260730
Any knowledgeable carb/ignition folks out there who can help with my situation?? My '68 Galaxie XL 390 4 speed bucks when I shift into next higher gear, if I do not have rpm's higher than what I would normally shift at. Also bucks if I take off at low rpm in 1st gear. I'm talking just normal driving, not hard acceleration.
Carb is a Holley 4010 (similar to autolite 4100), plugs look slighlty lean (not bad), gas mileage lousy though!! (9-10 mpg suburban driving) Stock ignition/distributor, stock exhaust. Retard timing does little, advance makes it worse. Runs very good other than bucking into 2nd or 3rd, 4th is fine.
TP
