Results 1 to 3 of 3
Thread: Catalytic Converter
    Los Angeles - California
    Catalytic Converter
    Is it worth replacing the CC's with high flow High-Performance converters.
    Or
    is it worth removing them?
    2004 BLACK MERCURY MARAUDER
    SCT
    JLT Cold Air Induction
    PHP Intake Spacer
    Cobra Ported Manifolds
    Flowmaster 50's
    Magnaflow X-Pipe
    Stallion TC
    4:10's
    Steeda Underdrive Pulleys
    Rear sway bar
    1969 GREEN MACH I MUSTANG GT
    351 Windsor
    Shelby Cam
    Shelby Tri-Y headers
    Ported and polished heads
    10.5:1 Domed pistons/rods
    Balanced and blue-printed
    Offenhauser Intake
    NOS plummed under intake (8 fuel injectors, 8 NOS injectors)
    Art Carr TC
    Tranny shift kit
    Dual ignition with MSD
    3:90 Posi rear end
    Bought car when I was 16 and still have it
    Larry Vogel Guest
    That would be a no- no to take em off. I believe they have a heafty fine. You'll have to check with sec of state as to the high performance ones, but I believe if they are approved for Calif. they will be alright.
    St. Louis, MO
    You can get Hi-Flow Cats. OR... if you're lucky and no one checks, you can just plain cut 'em off and replace the O2 sensors with emmulators...
