Okay I've got an oil pressure test kit hooked up and I'm trying to find out what the oil pressure should be once warmed up at idle. I have the SVT Cobra engine in my car all forged internals. Right now it's showing 14-15 psi warmed up.
Around 25PSI is where mine sits.
2004 Mercury Marauder
2,187 of 3,214
997 in Silver Birch
448 with light flint interior
304 with heated seats
336 with sunroof
So 13 to 14 PSI is on the low side then right? The reason I got it low pressure test kit is because the aftermarket auto oil gauge when the car is warmed up always reads 0 and I asked the guy i bought the car from. Anout it he said it's done that since the engine was installed. He said that was around 70,000 miles ago, or so. Now once you start driving and getting to RPM little raised up to round 20 and 30. Now with the oil test kit it showed 14 to 15 warmed up at idle and at 2000 RPM around 40 PSI
Anyone else with built engine have any info give?
My engine when started up cold would read close to 75 psi at high idle. Once it was warmed up at normal idle it would read 10 - 15 psi. I thought that was kind of low, but as soon as you revved it up above idle...it would show plenty of pressure.
There is almost no load on the engine at idle. You want plenty of oil pressure as the revs build.
It seems low under all circumstances. There are factors though, which oil pump, high volume or not, viscosity, how fresh and grade, thermostat 170 or 180 when up to temp. But 60/80 when driving 30/40 at idle.
Anything above 7psi is fine
Mine is around 12 -15 at idle almost 80 when cold 40 - 60 at revs when warm
Steven
2004 Marauder Black, loaded
Vortec S/C
4.10s
3500 PI Stall
Kook's headers
476.9 rwhp 385 lbs/tq
Lidio tune
2004 Suburban Dark Charcoal
A good rule of thumb is 10 psi per 1000 rpm. Idle oil pressure sounds okay to me.
Stock engined MM w/ 90+k miles.
Cold over 100PSI
Warm at idle 20PSI
3.35 L 4X4
-AND-
SLAYER1
I recommend you check your gauge against a known source like a tire pressure gauge or the gauge on your air compressor. I've seen more than a few oil pressure gauges that weren't even close; especially service gauges.
