Results 1 to 15 of 18
Thread: Upgraded Exhaust With Delete Tips?
    Aug 2004
    Altamonte Springs, Florida
    Who has done an exhaust upgrade, and changed out the tips? Was it worth it? I have installed the Ford Dual Mode Mufflers, and am somewhat happy, but I think it could still be a little louder.
    I am considering the Meg's Delete Tips, but I would like to hear from someone who has already been through this, to see if it is really worth doing. I just feel that the stock tips might not be letting the duals show their stuff.
    Any help will be greatly appreciated.
    Thanks.
    John
    (oldekid)
    2004 DTR MM (Reba)
    Build Date: 05/25/2004
    # 3020 of 3213
    # 931 of 981 DTRs
    Jul 2003
    Las Vegas
    I have
    I have the Megs delete tips installed. Got them from Wes Chain, a supporting vendor on this site. They are awsome, the first time they started the car with them one there was a loud WOOOSH from the tailpipes that sounds great, louder at all throttle positions , I would get them. I do have the 40 Sereies flowmasters though, so im not sure how the dual modes would sound.
    Lakewood, OH
    I have Flowmaster 40 mufflers, and the Megs tips. I woudln't necessarily describe the sound as a woosh. I had both mods done at the same time. Both mods together compliment each other well. The sound is great, louder, deeper, the tips allow for more of a burble/rumble at idle. If you get the tips, it will compliment your mufflers. Hope this helps.
    -Mat
    2004 Black Mercury Marauder
    Trilogy Eaton Intercooled Supercharger #200
    483 RWHP 471 RWTQ @ 13.5 lbs of Boost 2.8" Pulley
    11.76 @ 116.25 1.65 60ft
    17,500 Miles
    Aug 2004
    Quote Originally Posted by LVMarauder
    Thanks, I appreciate the input. I'll probably end up ordering them. I'm sure they can't do anything but help.
    John
    (oldekid)
    2004 DTR MM (Reba)
    # 3020 of 3213
    # 931 of 981 DTRs
    Jan 2007
    So CAL
    I have them too but I have a set of Borla Mufflers and the sound is very deep instead of loud. I love the sound.
    Sep 2004
    Southwest MO
    Can you give me more info on the Ford dualmode mufflers? Is there supposed to be a performance gain, or just sound level increase?
    Jan 2006
    Edmonton, AB
    They work pretty good, I have them in my Cobra. It sounds stock at idle, but when you hit it above ~2000rpm the back pressure opens a valve inside the muffler making it sound almost like straight pipes. It's all based on engine load, I can have a quiet conversation with a passenger while cruising at 4500rpm or drown them out with a blip of the throttle at 3000. Sometimes it does see a little too quiet though, even with an aftermarket X-pipe.
    more info:
    http://www.mercurymarauder.net/forum...t=13688&page=3
    Keith,
    03 Marauder
    Apr 2005
    The Pitt, PA
    I have magnaflow 14's. Pretty much straight through mufflers with delete tips. I get gobs of compliments from Marauders owners and general public on the sound!
    2013 Ford Taurus SHO
    #1649
    boi
    Jan 2005
    Just South of Memphis, TN
    Quote Originally Posted by Herco23 View Post
    Which Borla mufflers are you running?
    are they quieter than the Magnaflows and Flowmasters..?
    I know it's a matter of opinion, but I was just curious as how you would describe them...
    Thanks, Architect
    "Ford Racing" 410 gear
    18"X8.5" Black Bullitt Wheels
    "Ford Racing" Center caps
    Black Wilwood Brakes (fronts)
    "Powered By Ford" coil covers
    30% Window Tint
    "X-pel" Light Shields
    "Pro-gard" skid plate
    Rear Spoiler
    "Kenny Brown" dead pedal
    "Megs" delete resonator tips
    "SS" Titanium Inserts
    Blacked out window trim
    Texas
    Quote Originally Posted by Architect View Post
    Thanks, Architect
    I had borlas on mine too. Universal fit stainless, I believe they were 18 or 20", with the 4" tips they sounded good, but not as loud as Flowmasters or Dynomax. When installing, be very careful, Borlas casings are very thin.
    '15 F250 CC 4WD 6.7L PSD
    '11 CVLX
    '05 E55 AMG
    '91 350SD Turbodiesel
    '97 Land Cruiser/78 Land Cruiser
    Oct 2003
    Beaufort, SC
    In my "QUEST" for the right sound (for me) the biggest volume change came with the high flow cats!! The "Old School" gurgle came with the custom "H" pipe.....Now the sound is PERFECT for me with no cabin drone!!
    I would be glad to email someone a sound clip of my car to post here since I don't have a clue how to do that.
    Everyone I spoke with discouraged the delete tips because of increased cabin noise (drone)!!
    Marauderjack
    Aug 2005
    TAMPA BAY & SNOW BIRD MAINEIAC
    FMS Dual Modes and 4" delete from Wes w/ Cobra Ceramic coated Manifolds w/ Magnaflow high flo cats and X pipe from Reinhard Automotive= Loud ..but they look good...to me at least. Dennis
    GOD bless my friends, Paula, Cheese(Rex) and Alex and all those still with us.
    Semper Fi
    SUPPORT THE WOUNDED WARRIOR FUND
    2012 HTRDR Lincoln MKT AWD Twin Turbo SHO Eco boost MOTOR
    04 DTR "FruitPunch"5/17/04 Living with the "LEMONADE" in Ed's garage...
    TRILOGY EATON #110 11-25-05
    TRILOGY Twin Screw #003 Thank you MCM & JERRY BARNES
    Install by THE STOOGES
    ASS TUNE by LIDIO
    "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery"
    --Winston Churchill
    Dec 2004
    Orlando, FL area
    Short vid clips of Magindat and myself at MVIV track meet:
    http://www.cardomain.com/ride/748029/2
    I have 14" magnaflows with stock tips. The quality isn't real good, but I think Magindat's sound is a bit deeper. Both sound darned good at WOT, though.
    If this was just a fun car for me to drive on sunny days, I'd probably have delete tips with magnapacks! But it isn't, so I like it the way I have it now. Mild at low throttle, screams loud at WOT.
    White Lightning Kiarauder:
    Black Thunder:
    Sequence number is 39 of 3213
    Traded in 12/12/10
    XCalibrator2/Reinhart tune
    Sequence number is 37 of 327
    Martyo's Garage!!!!!
    Dec 2005
    Kelowna B.C. Canada
    I have sound/video clip of stock and then after with flowmaster 40's and res delete tips if you want it PM me.
    Sep 2004
    Southwest MO
    Marauderjack
    So, you're running stock mufflers, hi-flow cats, and a custom H-pipe?
  1. Cabin Noise
    By merc in forum Exhaust
    Last Post: 03-14-2006, 09:04 AM
  2. Delete Exhaust Tips
    By JFB in forum Community Discussion
    Last Post: 02-06-2005, 10:29 PM
  3. Meg's Resonator Delete Tips Self install
    By teamrope in forum Innovative Interceptors
    Last Post: 12-27-2004, 11:24 PM
  4. Replies: 20
    Last Post: 05-01-2004, 09:07 AM
  5. SLP exhaust tips?
    By khc3 in forum Community Discussion
    Last Post: 02-06-2004, 12:59 AM
