Results 1 to 7 of 7
Thread: signal/turn light socket
    I just notice today that my Left Turn light (signal) socket is poking out of its port. How hard is it to plug it back in?
    anyone know?
    Apr 2005
    The Pitt, PA
    Front or back?
    2013 Ford Taurus SHO
    #1649
    boi
    Elwood-Home of the "Blues Brothers"
    PITA> Have to remove the whole signal corner lamp to access it, this involves removing to get access. I replaced my right corner lamp (sc***** up), had to remove the battery. Started on the left one to adjust it, gave up when I saw what all I had to remove just for an adjustment, gave up. Not enough time then.
    I can't hear the noise in your head. Please keep it that way.
    Quote Originally Posted by knine View Post
    WHAT????
    Just take out the headlight on that side and loosen the nuts holding the cornering light assembly. Replace the bulb, reinstall the headlight. After you take the headlight out you might want to modify it like this.
    This is stock
    This is modified
    Makes it easier to come out next time.
    Wow, so much easier.
    So the 2 or 3 nuts and take the light assembly off the car then just pry it open?
    ok.
    Thanks.
  1. How many forum users does it take to change a light bulb?
    By 2003Marauder in forum The Lounge
    Last Post: 03-30-2007, 11:32 PM
  2. Clev. Meet Beer/pop List
    By CRUZTAKER in forum Events
    Last Post: 06-08-2006, 08:02 AM
  3. Help, Check Engine Light at 16K!!
    By redstripe in forum Shop Talk
    Last Post: 08-01-2005, 08:28 PM
  4. Replacing a Light bulb...
    By Logan in forum The Lounge
    Last Post: 03-18-2005, 08:05 AM
  5. Marauder Has Good Showing @Drag Strip
    By sailsmen in forum Community Discussion
    Last Post: 10-04-2004, 05:05 AM
