Results 1 to 15 of 22
Thread: Should I sell my car as a whole or should I part it out?
    Dec 2016
    Chicago
    I own the worst Marauder that has ever existed. It is way more trouble than it's worth and I just want to get rid of it. Here is the shape of the car:
    The good (believe me there is not much to put here):
    -The transmission was recently rebuilt
    -The alternator was replaced with a new one (I still have the old one and it's an original part)
    -The engine needs a degreasing but other than that only has a few leaks (one around the PCP valve and the other around the drain plug)
    -The leather seats were replaced with another kind of material. I'm told it's ostrich
    -The battery was recently replaced
    -No suspension issues other than rust
    -It has a new ECM and passed emissions two months ago (The check engine light is on now however due to a misfire in Cylinder 4)
    -While it has had a recent (although horribly amateur) paint job the original color of the car was silver (The exterior code is JP)
    -It's a 2004
    -It has a spoiler and, surprisingly, the trunk is original
    The bad:
    -There are only three original tires. The fourth tire on the car as of now is the full sized spare that came with the car. One of the three original tires has a bent rim and as of now that tire is shredded.
    -The front end is horrible. The front bumper is from a Grand Marquis and it's in horrible condition.
    -The front grille is also from a Grand Marquis. It's in good condition
    -According to a sticker on the underside of the hood it's from a Crown Vic
    -The sunroof button panel is taped on as it kept falling off
    -One of the front headlights is from a Grand Marquis. All other lights are original
    -The shifter is functional but in two pieces
    -A piece under the glove box fell off so a bulb attached to some wire currently rests on the ground
    -There is no radio and the antenna wire has been cut
    -The mirrors are glued on
    -The back bumper is intact but has a crack on the bottom right side right near the exhaust.
    -The coil pack will need to be replaced soon
    -Needs a power steering pump
    -One of the center caps was so loose I just took it off. I still have it
    -The exhaust pipes are not aligned
    -The tires need to be replaced
    Parting out is a lot of work, packing and shipping so parts are not damaged, but the parts are worth more than the whole a lot of times. Depends on how quick you want to be rid of it.
    Zack...you were looking for a silver, but maybe not quite this amount of work?
    Dec 2016
    Chicago
    I just want the most amount of money I can get for it. If parting out will get me more money than I might go that route.
    Just sell it
    Dec 2016
    Chicago
    How much do you think it's worth?
    Pictures please
    Quote Originally Posted by Maimed Marauder View Post
    Without pictures and a location, $8.
    Trilogy # 192 / T.S. 0012
    So will $500.00 buy it? What amount are you thinking?
    $500 and everyone is a player. Zack needs this car.
    Doesn't sound like the car was the worst that ever existed, more like the owners..
    Ostrich seats... just what I always wanted.
    Feb 2015
    South Florida
    Post some pictures...
    Righteous Indignation
    03 300A
    4055 of 7838
    4054 of 7093 in Black.
    Born 8/23/02
    Adopted in 1/15
    SOLD
    Jan 2015
    Mishawaka, In
    Sell it, the time taking it apart won't add up to anything that seems worth while
    Dec 2016
    Chicago
    north nj (Planet Houston)
    those pictures make me sad.
  1. Used car best buys
    By dwasson in forum The Lounge
    Last Post: 06-05-2006, 07:49 AM
  2. (OLD THREAD) Trilogy car will be in Columbus OH July 26-27th
    By Lidio in forum Trilogy Motorsports
    Last Post: 01-15-2006, 08:51 PM
  3. S/Ced MM the best all around car?
    Last Post: 08-24-2005, 04:14 AM
  4. Hack Takes the Trilogy SEMA car to the car show
    By Hack Goby in forum Community Discussion
    Last Post: 07-10-2005, 10:06 PM
  5. MM Driving Impressions (kind of long)
    By Eric91Z in forum Community Discussion
    Last Post: 10-25-2004, 04:27 AM
Tags for this Thread
