Results 1 to 15 of 22
Thread: My rear is lumpsided
    adrian36 Guest
    My rear is lumpsided .5 inch difference!!!
    Ok, enough with the comments I have noticed that the driver's side rear is about .5 of an inch lower than the passenger side rear. I have moved the car to even pavement, had my neighbor 250+ pounds to sit in the rear and the car sinks but the air bags kick in and the susp. rises. I had him sit on the pass. side rear and the susp rises but the driver side is still .5 inch lower.
    The rear driver side is exactly .5 inch lower than passenger side rear. The front is completely even 29 3/8 and 28 7/8= .5 inch lower.
    Please any ideas or suggestions will be appreciated. Thanks
    Is it normal for the car rear susp to be off by .5 inch or should I take it in for warranty??? Any help would be appreciated. Thanks
    Aug 2002
    New Orleans, La
    Quote Originally Posted by adrian36
    Ardian, how are you taking these measurements ?????/
    drobin
    "Donald"
    03MM-300A
    Build Date 6/05/02
    673 of #7093 Black
    Your car hasn't been in an accident has it???
    adrian36 Guest
    It is obvious to the naked eye
    Quote Originally Posted by drobin
    drobin
    "Donald"
    I am measuring from the ground up, center of rim to the fender. The right way. help
    adrian36 Guest
    No accident.
    No accident, clean only 9800 miles
    Misquamicut, RI
    Are you refering to the rear bumper cover? There have been threads refering to this problem here. If it's the actual frame height that's off, I would take it in. I'd take it in for the bumper cover also. Either way, you spent good money for a new car and it should be right, and even.
    300A
    born 08-27-02
    Adjusted air in and air out.
    400+ timeslips.
    adrian36 Guest
    No,not the bumber cover
    I stand in front of the rear tire facing the rim god's head. It is sagging .5 inch on driver side rear. Pass. side ok
    Misquamicut, RI
    Definite trip to the dealer is what you should plan. My buddy had one with both sides of fenders down over wheels (fender lip covered top of tire). It just plain didn't look right, especially next to mine. I told him, he agreed that it was different, but he liked the look. There is a sensor for the air suspension, I don't know if it can be tilted, but you can adjust overall ride height with it. When you put the smaller front springs in, it's how you restore the original rake to the car.
    300A
    born 08-27-02
    400+ timeslips.
    Connecticut
    It sounds to me that what Paul is talking about is much more serious. I wouldn't go to the dealer just yet if I were you.Not to sound rediculous, but if you're measuring it that way(from the wheel to the fender lip), then have you also checked the PSI in both back tires before you do that w/a tire pressure gauge that's accurate as well as repeatable? I wouldn't measure it that way. I use a flexible tape measure and take the measurement from the pavement to the fender lip. That way, you take the tire inflation differences out of the equation. And by doing it that way, you just might find that there's only a 1/4 inch difference between the left and right sides. Which is nothing. Personally, I wouldn't even worry about a 1/2 inch difference either. That isn't even something you can see. My Vette was the same way. The only reason I measured it was because I just replaced the rear spring.
    But you might want to make sure that one of your rear shock absorbers aren't broken in half or bent right in the middle. I say this because of the fact that when my Marauder had merely 4,000 miles on the clock, I noticed that the driver's side rear shock was broken in half, and the passenger side rear shock was bent right at the same place. And I didn't even know it. The only reason I noticed it was because I went to remove the snow tires that I had on. I assumed the shocks were broken because of the boneheads at one of the dyno places that I went to, since they put the tiedown straps around the shocks (I learned about this at a later date) but now you have me wondering if it was due to faulty shocks. Some people claim that shock absorbers cannot effect the ride height at all, but I know for a fact that this theory is NOT true. The shocks won't effect ride height as much as the springs will, but they WILL effect it to a lesser degree. Anyway, I suggest that you check the two things I mentioned, and get back to us to let us know what you've found. I'm routing for ya here.
    adrian36 Guest
    I did as you stated.
    I measured from the pavement up the center of the rim to the fender. I did check the psi in tirew with a digital tire press. guage. Tire press. even. I cant see why it would be off by .5 inch. It is obvious to the naked eye. I will call the dealer to see when I can take it in.
    I believe there are specs for measurements from frame to ground, probably in alignment or frame straightening specs. If the measurements from frame to ground are ok that should rule out a suspension issue, then it would most likely be the body mounting bolts/bushings. I have heard of these being loose on some cars, usually the complaint is a clunking noise in the rear.
    Connecticut
    I don't know what made you even measure that in the first place, but I bet that if you went in a parking lot and started taking those same measurements from left to right on peoples' cars, that you would find that same 1/4 to 1/2" difference on more than half of the cars on the street that have more than 5,000 miles on them. It would be another story if the difference was 1.5" or more. I still think it's no big deal unless one of your rear shocks are broken, but it's your car dude. If someone is driving behind your car they would never notice an uneven ride height. That's what I meant. You notice it, since you've measured it, and you know it's there. But I think you're worrying about nothing. BTW, I hope you checked the shocks like I suggested.
    adrian36 Guest
    Will check and keep all of you posted. Thanks again. Plan to go to dealer on Thurs 9-16
    Plano, TX
    This past weekend at the track, I noticed a differnce in my rear ride hight as well. I haven't mesured yet, but it's no more then 1/2 inch. I'
    m not to worried about it at this point.
    Gone, but not forgotten
    Off-Shore America
    My MM is likewise off the mark. My left front is higher than the right front, and in the rear, the right side is lower than the left. I thought about it, and I think is't just the body/frame adjusting to the torque under hard power. I can't say it's noticable, I didn't detect it. I only noticed while writing down my specs. I don't think it's a sign of any problems, IMHO.
  1. Window Tint
    By PAPAJOHN in forum Community Discussion
    Last Post: 11-11-2010, 04:31 PM
  2. Rear differential cap/girdle...observation...
    By FiveO in forum Shop Talk
    Last Post: 08-02-2004, 04:18 PM
  3. Replies: 1
    Last Post: 07-19-2004, 07:39 PM
  4. Replies: 35
    Last Post: 07-18-2004, 06:50 PM
  5. Check the rear ends.
    By tomd in forum Shop Talk
    Last Post: 04-23-2003, 08:49 AM
