Results 1 to 15 of 15
Thread: Electrical Problems
    Feb 2005
    Parkton, MD
    Exclamation Electrical Problems
    After having my car detailed yesterday, I drove to get some gas. During the ride, the A/C was working fine along with all other electrical systems. After my fill-up, I turned the ignition, the car started fine, but no climate control of any sort, no interior lights, no clock, no exterior lights(underbody lighting kit). Everything else is working fine. Any ideas?
    Just another clown on a bike...
    As good as any man, better than none.
    Former owner of a highly modified and very fast Marauder.
    "You CAN fit a square peg into a round hole, all you need is a big enough hammer." -Original
    Check the fuses?
    Did they detail the engine bay?
    TRILOGY № 86 - 13.5PSI
    Feb 2005
    Parkton, MD
    Yes. Power washed, but... after the wash, another guy came in and removed the headliner and console to pop out a ding in the roof. He said all of the elecrical was working when he was inside the car.
    Quote Originally Posted by blackf0rk
    Quote Originally Posted by Cheeseheadbob
    Power washed
    Oooooooh...bad idea...modular motors no likey...hopefully after it dries out the problems go away. I would avoid power washing the engine bay in future...too many electronics.
    May 2005
    Amissville VA
    I'd inspect it and see if you can find any water pooled anywhere or possibly loose connections.
    I remember when my dad brought his CVPI home we washed out the engine bay. Water pooled in the spark plug hole (SOHC motor, no coil covers/gaskets) causing a misfire.
    Since then I do all engine cleaning by hand.
    It could be a fuse, maybe a common point where all this is wired together possible a connection is loose.
    Trilogy #112 (self installed)
    12.99@106.2mph (for now)
    Ahh yes the good ole' power washing engine bay no electrical stuffy work trick. Give everything a few days to dry out and see if that happens. It took me 3 hrs to clean my friend's mustang 2v engine only using simple green, a tooth brush, easy off oven cleaner and a big squirt bottle full of hot water. That reminds me I need to start cleaning my car for the Safford L/M gig.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    I have been power washing my engine atleast once a month for almost 3yrs and have on all my pervious cars and i never had a problem. my modular motor dont mind a bath
    BAD DTR MERK 04
    Quote Originally Posted by michael ward
    You must be washing like a smart person then
    Wash
    I had my car washed and inside cleaned and when I got home I later went out at night with the car. When I started it, I had no clock or interior lights, no climate control lights...it was all dark. The had turned down the interior light knob all the way down. Took me a few seconds to figure it out.
    Check you dimmer.
    18psi pulley
    Billet Oil Pump
    ARP Bolts and head studs
    Snow Methanol Injection
    3500 Stall Converter (PI)
    Stryker 340 Fuel Pump
    45 lbs Injectors
    4:10 gears
    K&N Air Filter
    Factory Spoiler
    Widened Wheels
    Nittos
    170 deg thermostat
    SS Inserts
    Trunk organizer
    Feb 2005
    Parkton, MD
    Thanks, that was the first thing I did.
    Quote Originally Posted by Mike Mielnicki
    Check you dimmer.
    Jan 2006
    Central Ohio
    Yup, let her dry out.
    I did the same thing to a Dodge Dakota a good while back. After drying out, all was good
    KillJoy
    Feb 2005
    Parkton, MD
    Problem solved!
    The dealer discovered that when the dent guy reattached the driver's side visor, the screw grounded out the wires that control power locks, climate control, clock, etc. and it blew the fuse. Wires and fuse replaced, car ready, and my next dent repair will be free!
    I discovered that the climate control and interior lights are on the same circuit a couple of years ago. I had a bad door ajar switch in one of my doors and so the interior lights would stay on all the time. Before I got it fixed I just pulled the interior lighting fuse and discovered that it took down the climate control as well. Glad you go it sorted out.
    2003 Mercury Marauder
    2007 Lincoln Town Car
    1993 Crown Victoria LX
    Apr 2005
    Queens NY
    I have done the same, I keep a distance when I spray and I make sure not to hold the spray in one place for too long.
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
  1. Problems! Problems! Problems!
    By Go Mifuni in forum Shop Talk
    Last Post: 11-23-2005, 12:36 PM
  2. F#$kin Electrical problems
    By Skiordie53 in forum Community Discussion
    Last Post: 08-17-2005, 11:56 AM
  3. 03 Marauder black paint problems?
    By metroplex in forum The Lounge
    Last Post: 06-11-2005, 10:10 AM
  4. Customer Service, Superchargers, and Problems
    Last Post: 03-12-2005, 11:03 AM
  5. Problems Fixed Mods Installed
    By JET in forum Shop Talk
    Last Post: 08-28-2004, 11:56 AM
