Results 1 to 15 of 18
Thread: Trans. Shudder
    NewBrockton AL.
    Trans. Shudder
    Not sure if shudder is right. But I have noticed that when I take off lately that the trans feels like it is slipping some or shuddering some when I first take off. Now not all the time. I have all so noticed that it does not seem to shift hard as it us to. I do have the J-mod done. Car has 22,700 on it.
    Anyone have some in put? All so some good place to maybe rebuild the trans.?
    trans
    03MM 300A Build date 06/03/02 Production #446Tilogy S/C Kit#4 387RWHP 364RWTQ, Addco front and rear sway bars,Factory Spoiler,Auto,Auto Meter Gauges ,Boost,Air/Fuel,Trans. Temp. Oil and Volt. All are real working gauges now.Badgeless Grill,J Mod
    Metco D/S Loop,Boxed Lower Rear Control Arms
    New Made Upper Rear Control Arms
    Boxed Watts Link,Ford Finned Rear End Cover
    Colex Caps: Oil,Water,Enter Cooler,Power Steering,Master Cylinder and Windshield Washer
    Daniels Coil Covers and Buttons,Nitto 255/45 front
    Widen Rear Wheels with 295/45 Nitto's,Zack's Big Brakes, Rear Drilled a slotted rotors,TCE Braided brake lines,Pro Guard Skid Plate,Summit trans pan, New Exhaust.K&N Cold Air Intake,JLT Catch Can,fastblackmerc door seal plates, pedal covers and Mustang dead pedal.
    I don't see how the trans needs rebuilt at 22700 miles
    maybe change the rear end dope, and put Ford friction modifier in there, this cured my shudder, clutches must have been sticking
    Dec 2007
    Berwyn
    Angry
    I started having the same problems after doing the j-mod. The car isnt shifting hard as it use too. Now im starting to think if theres something wrong with the rear end and not the trans.
    Mo's tune, 4.10s gears, steeda udp, K&N CAI, PHP Intake spacer, 180 thermostat, autolite xp104s,granatelli high output coil on plug connectors
    Oct 2010
    Michigan
    I had the same thing happen and had to get my tune adjusted.
    NewBrockton AL.
    I am thinking the same about my rear end. I changed the oil at 22,000. But like I said it makes some nose when I turn hard to the right going into my drive.
    Rockford
    Blown cars can eat transmissions.
    Is your convertor stock?
    What tune are you running?
    Friction modifier , can help a shudder , but I've only heard of using it if the shudder is while cruising at speed.
    Hiram, Georgia
    Quote Originally Posted by risky View Post
    Your trans needed to be rebuilt.
    NewBrockton AL.
    Marty I was hoping you would comment. Who would you recommend?
    Hiram, Georgia
    Quote Originally Posted by Bob Mathis View Post
    The guy we use at our shop does a great job and we have had zero issues.
    I do not know what is wrong with your car from comments on the internet but you are welcome to ride out to us and we will look it over.
    NewBrockton AL.
    I may just have it rebuild. I would just like it to be able to handle the power with out worrying about it.
    Oct 2003
    Beaufort, SC
    You are nowhere near the power level or miles that would cause a stock transmission to fail Bob!!
    Take it to Marty and let them check it out.......probably need more Friction Modifier in the rear end!!
    BTW, my OEM transmission went 177K miles before it started slipping and the last 93K miles were with the blower!!
    Good Luck!!
    Rockford
    Talking That's a know brainer!
    You don't have a choice, unless you like to push it .
    NewBrockton AL.
    Took the car to my shop and added a little more modifier. I all so found my cold air tube had come off the TB. Had a rough ideal. Not sure if is was out enough to cause the system to go nuts. But cars does good for now. We shall see.
    Oct 2003
    Beaufort, SC
    Unmetered air will cause all sorts of crazy stuff to happen......sounds like ya found your "Trans Problem" Bob!!
    Now, drive it and quit worrying about it!!
  1. Transmission shudder....
    By dickmerc in forum Transmissions
    Last Post: 04-28-2015, 02:28 PM
  2. Shudder and shake...
    By ik04 in forum Steering, Suspension & Brakes
    Last Post: 03-26-2012, 08:41 PM
  3. Transmission shudder
    By Leadfoot281 in forum Shop Talk
    Last Post: 09-22-2005, 11:41 AM
  4. Brake shudder?
    By MTAMERC9 in forum Community Discussion
    Last Post: 05-20-2005, 03:50 PM
  5. Shudder
    By 01True BlueGT in forum Shop Talk
    Last Post: 11-27-2003, 10:14 AM
