anyone know for sure if the Ranchero frame is the same as a sedan, or a station wagon, or unique??
Thnx
Thnx
http://www.ranchero.us/forum/index.p...ro-frame.2549/
read this thread, sounds like 1973 ranchero = 1973 gran torino station wagon...but 1972's are different than 1973's. need to look at Ford master parts catalog or a 1973 tech service manual...
J.P. - The 1972 Torino wagon (type code 71) and 1972 Ranchero (Type code 97) share the same Frame - Ford P/N D20Z-5005-C. Not sure if any interchange on later model years. This info come from the 1972 edition of the Ford Master Parts catalog, so I gotta think it is valid info - Hope this helps - Ed
I doubt the frame from this Ranchero would work:
I will try to remember to look it up tomorrow on our old Ford micro-fiche machine. Writing myself a note....….
After reviewing the answers, looks like Agent2006 has a very plausible answer and the frame part number looks correct for the vintage.
Thnx all. Quite the contraption on the extended blue Ranchero. Not my style.
I have seen a Ranchero sitting on a 4x4 frame, not bad.
