Results 1 to 10 of 10
Thread: Lower Ball Joints
    Aug 2007
    INDIANAPOLIS
    Lower Ball Joints
    Has anyone replaced their lower ball joints?
    Dec 2017
    Ellicott City, MD
    I bought the whole lower control arms. But borrowed the ball joint press from advance auto to try to remove original ball joint from oem control arm. Had not problem removing. Didn’t try putting it back in though.
    You can press them in and out, manufacture doesn’t recommend as the control arms are aluminum and can crack.
    Trilogy # 192 / T.S. 0012
    Buy new. They are inexpensive.
    Apr 2010
    South Florida
    I replaced the whole arms complete:
    May 2009
    Moreau Island
    What ever happened to the fabbed arms someone was looking into, think it was Tommy at Sparta.
    Timbuk3, MI
    Arrow
    Replaced the entire control arms ...
    *NAPA part #s - 260-5262 (RH) / 260-5261 (LH)
    Aug 2007
    INDIANAPOLIS
    Thanks all! When I had new tires Installed the techs said my lower ball joints were bad, especially the left one. I could have sworn I replaced the l driver's side. I'll have to check my receipts. Correct me if I'm wrong, but I believe you jack the front wheel up a few inches off the ground then use a prybar to pry upward to check for play.
    Thanks!
    Oct 2004
    I just had both my lower control arms replaced at 108,000 miles. Only way to go new bushings and ball joints. Now all is nice and tight. Also had car fixer alignment specs. done.
    Maryland
    I've done it both ways, they are easily replaced with the ball joint press, if you have the funds replace the whole arm, be sure and buy quality parts. There's alot of junk available now
    601rwhp 592rwtq @19psi
  1. For Sale OEM lower ball joints for 2003+ MM, CV, LTC and GM
    By megaforcer in forum Marauder-specific Parts for Sale
    Last Post: 10-14-2017, 08:31 AM
  2. Ball joints
    By adrian3691 in forum Shop Talk
    Last Post: 05-07-2014, 05:12 AM
  3. For Sale OEM lower ball joints
    Last Post: 03-25-2011, 10:29 PM
  4. ball joints
    By burt ragio in forum Shop Talk
    Last Post: 01-03-2011, 06:43 PM
  5. Ball joints.
    By Matt Johnson in forum Shop Talk
    Last Post: 08-29-2007, 07:12 AM
