Results 1 to 15 of 19
Thread: Valve Cover Bolts
    May 2003
    Dearborn, MI
    Valve Cover Bolts
    Does anybody know if chrome valve cover bolts are available for the 4.6 DOHC, and if they are, where I can get them. If chrome bolts aren't available, can I buy just a set of new valve cover bolts from the Ford/Mercury dealer?
    Apr 2005
    Frederick County, MD
    Yes, you can buy replacement bolts from the dealer.
    I don't know of a 'kit' for the 4.6l DOHC, but you could remove one figure out the thread size/pitch and length and order your own (ie ARP)
    That's what I did for my car since I couldn't find a kit available. The SOHC uses M6x1x30?mm bolts for the valve cover in all positions, but some have a stud over top. Haven't pulled any from my DOHC to give you a definite size.
    *BTW, would recommend the polished stainless bolts instead of chrome
    Modifications
    Click My Merc for more Pics!
    Feb 2005
    St.Louis, Mo
    If you can't find the bolts you might be interested in just bolt covers. He also does custom work you might ask Daniel about doing some for you.
    http://www.colexcustoms.com/
    Born 03/04
    Adopted on 01/03/05
    Now Procharger boosted #04
    Oct 2004
    Kentucky
    Arrow
    Since my car spends a good portion of its time at car shows and cruises, I have also been looking into this.
    UPR sells bolt "caps".
    http://www.uprproducts.com/shopping/shopexd.asp?id=721
    I might pick up an extra set of OEM bolts and have the unthreaded portions powdercoated.
    As Drock mentioned, there might be some aftermarket companies that supply stainless steel bolts.
    1. Black Sunshine (2003A F.I.T #3) (SOLD!)
    2. 2004 SAP P71 (Gone)
    3. The 2001 P71 (Flying Snow). (Sold)
    4. The 1998 P71 Jinbei. (Sold)
    5. 1990 5.7L IROC-Z (Sold)
    Keeping a black car clean is not a hobby. It's a part-time job.
    Support the troops.
    Jun 2005
    long island ny
    i have seen the bolt covers yhey look good
    May 2003
    Dearborn, MI
    Thanks for the replies. I'll look into the bolt covers. If I end up getting new bolts from the dealer, are they sold as a set, or individually?
    May 2003
    Dearborn, MI
    Wow, that stuff from Colex Customs is totally cool, I will definitely be talking to them!
    Oct 2004
    Kentucky
    Question
    Quote Originally Posted by Drock96Marquis View Post
    Anyone know the measurements for these bolts?
    I wonder if McMaster-Carr might offer some replacements.
    Support the troops.
    May 2003
    Dearborn, MI
    I'll pull one out and figure out the thread pitch and post it. The problem is the heads of the bolts are way larger than a normal bolt (a bolt of the same thread diameter) so finding a replacement other than at the Ford/Mercury dealership is gonna be a little hard.
    Quote Originally Posted by DearbornDave View Post
    exactly. maybe get the heads chromed? not sure if they could do that
    May 2003
    Dearborn, MI
    Ok, valve cover bolts are M6x1 thread, 25mm length of thread, 13mm hex size with a 19.6mm flange around the hex. I've checked with Gardener Westcott and they don't have anything like this. You could probably get a standard M6x1 chrome bolt and a chrome washer, but that wouldn't work for the bolts with the studs on top that are required in certain spots on the valve cover. I'm just gonna go to the Ford dealership and order new bolts and take them in and have them chrome plated. I figured someone would make chrome bolts for the Mustang guys and I could use them too. Oh well, it seems like with the MM nothing is that easy.
    i wouldnt get the threads chromed!
    or maybe you could just wire wheel it off once there done?
    May 2003
    Dearborn, MI
    Why wouldn't you have the whole bolt chromed? I've used chromed bolts before and never had a problem with them. Are you worried about the chrome making the diameter and thread bigger? Chrome is pretty thin and if there was a problem I could always run a die over the threads. (I'm a tool & die maker, I got all that stuff at work)
    never seen a chromed bolt nor delt with it very much. sounds like you know more then i. i just know aluminum is very soft and definitly would NOT what to eff up the treads on my heads
    May 2003
    Dearborn, MI
    I've got a 1969 Chevelle convertible, and pretty much the whole engine is put together with chrome plated bolts. Chrome only adds a couple thousands of an inch at best to the diameter of a bolt. Believe me, I know aluminum is soft too and there is no freakin' way I'd ever do anything to screw my engine up. Thanks for the concern
  1. Valve cover removal
    By FastMerc in forum Buckeye Marauders
    Last Post: 05-15-2008, 05:05 PM
  2. Valve cover pain
    By 03MERCMARAUDER in forum Community Discussion
    Last Post: 03-21-2006, 06:18 AM
  3. Valve Cover Leaking?
    By MM2004 in forum Shop Talk
    Last Post: 02-23-2006, 07:35 PM
  4. Valve cover paint
    By Mike Poore in forum Community Discussion
    Last Post: 12-19-2004, 11:58 PM
  5. Replies: 3
    Last Post: 02-06-2004, 10:44 AM
