Results 1 to 12 of 12
Thread: Valve cover removal
    Sep 2009
    Greenville, NC
    Valve cover removal
    Alright I am going finally going to ask this question. I didn't want to ask it because some of you might think what an idiot I am, but how do you get them off. All of the bolts and obvious stuff has been taken off. I did this a couple of years ago, but I can not remember how to take them off again. The passenger side one is hitting the heater box. It seems like I had to take off some kind of cover on the driver side to get the driver side valve cover off and loosen the motor mount. Can someone please help me?
    Quote Originally Posted by tallpaul View Post
    I assume you mean the cam covers......
    Drivers side comes off easy.
    To get the passenger side off I had to remove the motor mount bolt on the passenger side and jack the motor up (used a 2x4 & jack on the oil pan). Once off you can grind down a boss inside the cam cover to make future remove easier. While you have the cam cover off you might want to replace the BCM. They are about $50.00 at the dealer.
    Apr 2008
    Central MN
    to get pass side out can be a pain but here is what I did first keep working on it it will come out some force may be needed try to take it easy on the HVAC unit. Ok now that its out look at the back bottom corner this area has a tab that causes it to hit I ground mine down a bit it doesn't leak but now it just drops right in and out if I need to.
    Sep 2009
    Greenville, NC
    Thanks for the help guys. What is the BCM and what does it do?
    Oct 2010
    Blower control module, it controls the blower motor (ie fan)
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Apr 2005
    Queens NY
    This will help for the cam cover removal.
    http://www.mercurymarauder.net/revie...2/cat/2/page/1
    2003
    MERCURY MARAUDER 300A
    Build Date
    5/31/02
    Sequence#
    #363 of 7839 Black Marauders
    Dyno tested power
    Best 1/4 mile time to date
    12.456@109mph
    Visit my Garage
    Blackened300a's Garage
    once you pull the valve covers once, it wont be so bad if there is a next time.
    Dec 2009
    dayton
    Valve covers,...cam covers,...same thing.
    Oct 2011
    Ventura County CA
    wont clear the cams if engine not lowered
    Apr 2005
    Queens NY
    Quote Originally Posted by kmac View Post
    Not true. I removed and replaced twice without ever touching the motor mounts.
    2003
    Build Date
    5/31/02
    Sequence#
    Dyno tested power
    12.456@109mph
    Visit my Garage
    Apr 2008
    Central MN
    yep like I said it is a pain to get out put I never lowered or removed anything besides the valve cover bolts. Also don't forget to grind that back corner down before reinstall if you do the cover almost falls in then.
    Jul 2009
    CAMer
    Mines has been taken apart literally 7 times in past weeks. Cowl and wipers, upper intake then cam covers. Not hard at all. It's together now and will be taken a part AGAIN to fix timing for a 3rd time and timing cover cones off for that
    392 Challenger YELLOW JACKET
    12.28@114 stock
  1. Valve Cover Bolts
    By DearbornDave in forum Shop Talk
    Last Post: 07-16-2009, 05:04 PM
  2. valve cover removal
    Last Post: 11-29-2008, 01:48 PM
  3. Valve cover removal
    By FastMerc in forum Buckeye Marauders
    Last Post: 05-15-2008, 05:05 PM
  4. Valve Cover Gasket
    By arejayesss in forum The Lounge
    Last Post: 02-21-2008, 11:41 AM
  5. Valve cover pain
    By 03MERCMARAUDER in forum Community Discussion
    Last Post: 03-21-2006, 06:18 AM
