Results 1 to 7 of 7
Thread: Cold weather has it ticking
    Apr 2003
    Rock N' Roll Hell
    Exclamation Cold weather has it ticking
    When I start the car when it's really cold (below 15) I'll hear a slight ticking sound. I'll rev it to 2,000RPM and it'll go away and go back to normal. This especially happens when the car has been sitting for over a week. I'm assuming this is a fuel injector or something getting stuck when it's too cold?
    This is no where near the lose spark plug issue I had a few years back. Rev it and it's fine. Drives fine too and you wouldn't hear the tick unless you tuned in for it. I don't always have to rev it, sometimes it'll be fine after I put it in gear and drive it.
    Anything to worry about? What could this be?
    Thanks!
    "Bye Bye, Johnny B. Goode."
    Oct 2003
    Beaufort, SC
    Cold oil movin' S-L-O-W Dom...just don't rev too much when it's really cold!!
    Probably nothing to worry about....I'm sure others will chime in!!
    Good Luck and Happy New Year!!
    Feb 2016
    Fleming Island, FL
    I've never had that problem (see location).
    Aug 2007
    las vegas
    Nether have I..............see location.
    My black 207k does it. Now since it's really cold out, it's not going away
    I believe on my car it's the rocker arm lash adjusters are gummed up, or not squirting
    https://youtu.be/Vju5oqfqf2g
    Some folks call them lifter tappets
    Zack also talks about clogged oil restrictors?
    I'm not sure if ours are like this
    https://youtu.be/KCkBGDuw4sI
    But I'll tear into mine sometime to check for bad lash adjusters
    Dom, what oil and filter are you using? Cold oil is very thick compared to oil at operating temp, and it's likely just a little varnish or something in one of the HLAs. You could try a Seafoam treatment or a can of MMO, but for God's sake don't go for any of those "motor flushes" or any other snake oil.
    Also, oil filters with a nitrile ADBV tend to get hardened with age and cold and allow oil to drain back down. Use a good filter with a silicone ADBV (like the Motorcraft FL820S).
    Apr 2003
    Rock N' Roll Hell
    I'm due for an oil change. Sounds like it's simple as that.
    Thank you all.
  1. Nitto 555R's & cold weather.
    By Cheeseheadbob in forum Tires & Wheels
    Last Post: 11-18-2005, 02:33 PM
  2. Power door lock sticking in cold weather
    By stevenp1 in forum Shop Talk
    Last Post: 01-22-2005, 02:43 PM
  3. Cold weather tire deformity?
    By TechHeavy in forum Community Discussion
    Last Post: 12-03-2004, 09:24 AM
  4. Cold weather power
    By muslhed in forum North Texas Marauders
    Last Post: 11-30-2004, 12:43 PM
  5. Exhaust resonance in cold weather
    By Thomas C Potter in forum North East Marauders
    Last Post: 01-10-2004, 01:09 PM
