Results 1 to 11 of 11
Thread: Factory Center caps..
    Dec 2004
    Franklinville,NJ
    Any suggestions for fixing loose center caps? They just seem to spin and are loose. Is this common? I have 3 that are loose and one that is not. Hoping to find a solution before I loose 'em. Quite 'spensive from what I see if and when you do find 'em.
    2004 Silver Birch (Sold 10.20.2008)
    2004 DTR (Sold 2.2.2010)
    2004 Silver Birch (Adopted 2.5.2010)
    This one is a keeper!
    Quote Originally Posted by drj02 View Post
    Pull 'em off and wrap a couple rounds of tape around the outside of the tabs and then press them back in, should take care of the problem.
    remove them, remove the metal ring, heat the plastic fingers up and spread them out a little. put the metal ring back on and pop them back in. should work great
    Dec 2004
    Franklinville,NJ
    Thanks! I'll try it and keep you posted on my success.
    My same method!!!....
    The correct method!!!
    Smithfield, Virginia
    I tried the rhythm method.
    WIN WIN!~ Zack
    Lake Charm, Fla.
    Coax Seal from Radio Shack....like silly puddy. Place a little dab
    at 12 and 6. Problem solved.!
    Gotta Love It!
    "Best of Show"
    MARAUDERVILLE IV
    ORLANDO, FL
    11/11/06
    Member #1031
    Conceived 2/25/03
    Born 3/21/03.. "7002 of 7838"
    METCO DS/Loop
    and still kickin' ass!
    Aug 2007
    Colorado
    Quote Originally Posted by Merc-O-matic View Post
    Gotta Love It!
    Do WHAT with a seal???
    On second thought, I really don't wanna know...
    <sorry - its' the drugs...>
    Oct 2003
    Beaufort, SC
    If you lose any let me know......I have 6 brand spanking new ones!!!!!
    Jun 2008
    I used a similar trick using a 2-part epoxy that my dad's work makes. Works awesome!
    Aug 2009
    Pinehurst, NC
    Um...so what do they call you, Daddy?
    Semper fi
    "Those that refuse to learn from history are doomed to repeat it."
  1. center caps
    Last Post: 02-11-2009, 06:07 AM
  2. center caps
    By Weaver in forum Marauder Parts/Misc. Wanted
    Last Post: 11-14-2008, 10:53 AM
  3. I want these center caps
    By whoskal in forum The Lounge
    Last Post: 09-14-2007, 07:50 PM
  4. Center Caps
    By Big House in forum Colex Inc.
    Last Post: 06-26-2006, 06:02 AM
  5. need center caps
    By BigMerc in forum The Lounge
    Last Post: 03-28-2006, 06:12 PM
