..to set the volume control for traffic, and can't find it in the manual, I changed the battery, and lost it.
"A street walking cheetah, with a heart full of napalm."
"If You can keep Your Head About You, While Others are Losing Theirs and Blaming It on You..."
"Sometimes it is wiser to remain silent, and seem a fool, than to speak, and remove all doubt."
"We've been looking for the enemy for some time now. We've finally found him. We're surrounded. That simplifies things."[5]
I believe that you press in and hold the volume button untill it shows up on the display and then using the select up and down button to make the change.
^ correct, then use one of the arrow buttons (sel?) to adjust the numbers on the display, the higher the number the more volume increase.
Black 2003 300A Marauder Build Date 06-02 100K Miles
Bought used 05/07/11
HID Morimoto Mini Projector Headlights (built myself), HID Morimoto Matchbox Projector Foglights, Pioneer Z140BH Headunit w/Pioneer 3 way speakers, XM Radio, backup cam, GMRS radio installed, LED backlit gauge cluster, tint, McGard & Gorilla locking lugs (all of them), Cooper RS3A tires, dead pedal, 4.10s, MO's Tune, 3" Fuel Filter.
00 White CVPI (KTA Car)
1995 Chevy Suburban K1500
Thanks I'll give it a try, this is the radio mounted volume control, not the steering wheel mounted, correct.
On the radio is where you will do this.
