i notice my rear passenger side sits higher than my driver side is there a way to adjust the ride height sensor
where is location of ride height
It's on the Watts link, above the rear axle.
I responded to your PM.
If one bag is leaking, the system tries to do what it can with the other. The sway bar and influence from the front suspension effect left to right height in the rear as well.
2002 White F250 7.3 - Turbo
ive adjusted the height sensor located driver side in the rear lowered it and still passenger side still higher than the driver side i raise it and same for some reason passenger is higher than driver side any help thanks
is there anything else i can do to adjust height really sucks looking at it, ive read a few people have this problem but no fix that i read about
Convert the car to Right Hand Drive. With the added weight of you now on the right side it may help balance it out. lol
2004 Silver Birch 300B
Exhaust by Greg
2015 Ford Focus SE Sport FWD
2010 Ford Fusion Sport FWD
300A Black
Some Marauders are just slightly more crooked than others. How far is it off?
My 2004 has the same problem and looks the exact same way. Right rear higher than the left rear.
That's why I hate the airbags suspension
Eaton M112 Supercharger ✓
Intercooler ✓
Lower intake plenum ✓
Coolant Intake Manifold ✓
TB Intake Plenum ✓
Throttle Body ✓
Cobra air intake tube ✓
Accelerator cable bracket ✓
Fuel rails ✓
39lb. injectors ✓
Cobra heat exchanger ✓
lower Metco pulley with hub ✓
Intercooler reservoir ✓
90mm Lightning MAF ✓
MAF to filter adapter plate ✓
Conical air filter ✓
Custom Gortch Brackets ✓
Heat Exchanger brackets ✓
Intercooler pump ✓
Intercooler pump bracket ✓
Ribbed idler pulley ✓
Belt tensioner ✓
Alternator Pulley ✓
Fuel Pump ✓
EGR delete kit ✓
New accessory belt ✓
Cooling tube ✓
IAT sensor ✓
Mine is too!!!!! Drives me crazy. There has got to be a fix. I really don't think my right is leaking.
