MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 02-10-2018, 11:04 AM
BAD MERC's Avatar
BAD MERC BAD MERC is offline
#2,187 out of 3,214
Trader: (3)
Clutched alternator issue... (?)
I don't spend a lot of time driving my Merc. She sits for months with no issues when it's time to turn that key. Recently I have noticed the battery dead or extremely weak and after a full charge (Motorcraft Maxx BXT 65-750) the battery tested ok. Took the car to work Friday and drove home without incident. Noticed last night with headlights and A/C the voltage drops to 10 with brake application at idle. The system reads 13.8 - 14.1 at idle with NO load (13.8 - 14.4 is norm). I am gonna remove the alternator and have it tested. I noticed the pulley clutch is locked and spins the stator in both directions. Is there a possibility the clutch may be slipping in the drive direction? I am familiar with the way these work but can they fail and allow slippage under load? I am having the alternator rebuilt and the clutch replaced but with 49K miles an alternator failure seems unlikely. Any opinions on this?
__________________
'04 Silver Marauder w/ sunroof - HID lighting, JL Audio / Eclipse DVD/NAV/iPod/camera, 4.10's, 2" drop, Progard, Delete tips, Billet Pedals, BC4E dead pedal, Lidio Tune, Mach1 chin spoiler, K&N CAI, TCE SS lines, Super40's, tinted tails, SS Inserts, Heinous Control Arms, Real oil gauge, Steeda UDP, lighted door handles.
2004 Mercury Marauder
#2,187 of 3,214
997 in Silver Birch
448 with light flint interior
304 with heated seats
336 with sunroof
  #2
Old 02-10-2018, 06:20 PM
BAD MERC's Avatar
#2,187 out of 3,214
Trader: (3)
The alternator tests fine. The clutch is seized. I didn't realize these require a special tool that gets used one time. This still doesn't explain the loss of charging power so it looks like a local rebuild since it's out anyway.
__________________
#2,187 of 3,214
997 in Silver Birch
336 with sunroof
  #3
Old 02-10-2018, 09:28 PM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
Itís the same tool used for VW, Audi, and a ton of German cars. I picked one up on EBay for like $6.
__________________
  #4
Old 02-11-2018, 09:04 AM
BAD MERC's Avatar
#2,187 out of 3,214
Trader: (3)
Excellent! Thank you for that because the Gates complete kit is in the $100 ballpark. I checked to make sure my harmonic isn't slipping. Even with the underdrive I raised the idle ~200rpm a decade ago and had no charging problem. This is the first puzzling issue I have had. Just bought this! https://www.ebay.com/itm/33-Spline-A...EAAOSwc6JaaECQ
__________________
#2,187 of 3,214
997 in Silver Birch
336 with sunroof
  #5
Old 02-11-2018, 04:02 PM
camaro_dude15 camaro_dude15 is offline
Junior Member
Trader: (0)
parts store experience says the Chrysler pulleys will fail in such a way that will allow it to slip in the drive direction cant say the say the same for the mm clutches as i have never had to sell one or even test one
  #6
Old 02-11-2018, 05:33 PM
BAD MERC's Avatar
#2,187 out of 3,214
Trader: (3)
Quote:
Knowing that and knowing mine is not working properly I will replace the clutch first and see if that alleviates the voltage issue. Thank you for letting me know because this may very well be a similar issue.
__________________
#2,187 of 3,214
997 in Silver Birch
336 with sunroof
  #7
Old 02-11-2018, 08:15 PM
justbob's Avatar
Sick-Speed play toy
Trader: (11)
Quote:
Thatís the one!
__________________
  #8
Old 02-11-2018, 10:47 PM
Turbov6Bryan's Avatar
I miss whitey here
Trader: (5)
Just buy a non clutch pulley. You will need one for a eaton swap anyway.
I bought my clutch tool on ebay for 5-6 bucks too!
__________________
04 DTR
03 Black 300A
03 Black 300A
03 C.V. Sport Silver Frost
04 Supercharged SILVER BIRCH
04 SILVER BIRCH NA
  #9
Old 02-12-2018, 12:03 AM
1Marauder's Avatar
Senior Member
Trader: (5)
Interested to hear the follow-up. Please let us know.
__________________
Tune, JLT, FlowMaster 42441 Res Delete, New Nitto 235/255 Bigcarsforever dead peddle & custom SRP peddles, 5 coats Zymoil Titanium, Addco front and rear sway bars, KYBs, 1/2 inch coil cut, Sparts Watts link and Control Arms, Car fixer alignment.
  #10
Old 02-12-2018, 05:55 PM
BAD MERC's Avatar
#2,187 out of 3,214
Trader: (3)
Quote:
Carfixer (Claude) is my neighbor and we were discussing it, too. He suggested doing a solid pulley swap first. Dorman makes a replacement clutch pulley but it's in the $75 range. A replacement alternator WITH pulley is $135.
I have a sneaking suspicion it may be slipping on the drive side at high RPM's. Plus it is 14 years old and has been powering 800 watts of amplifiers for the same amount of time.
Follow-up after a few different things are tried.
__________________
#2,187 of 3,214
997 in Silver Birch
336 with sunroof
  #11
Old 02-12-2018, 09:01 PM
I miss whitey here
Trader: (5)
Pull the brush pack off, is one brush stuck or worn out? When my alt stopped working, one of the brushes was done.
Its just a few screws 4 to pull the bracket, and i think 2 more for the brush pack. I dont think the pulley is the issue (ya never know), you can get the pulley for free at a bone yard.
Also the MGM has the clutch too..
Let us know.
PS/ I think its funny is nobody really talks much about the alt here, i was wondering if the cop car 200 amp with our PWM regulator bolted on to it would make it work. IDK... too many irons in the fire at the moment. But that would be cool if we could get a cop car one, and bolt our regulator on it and have a simple mod swap for our cars thats ford proven. Aftermarket and reman can suck my left one
__________________
04 DTR
03 Black 300A
03 Black 300A
04 SILVER BIRCH NA
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
For Sale alternator with new OEM clutched pulley lifespeed Marauder-specific Parts for Sale 0 06-06-2014 12:42 PM
alternator issue still.... montyd Shop Talk 33 10-26-2012 10:40 AM
Alternator/Batt issue wrc7732 Power Adders 24 08-12-2009 06:17 PM
Alternator Issue? 10741 Shop Talk 4 06-03-2007 06:33 PM
Alternator: clutched or not? TripleTransAm Shop Talk 22 12-04-2005 03:54 PM
Powered by: vBulletin
