I do!!!!
I could not imagine my life without these
I do!!!!
I'm down to a handful or two. It was silly how many I had collected so I started pitching the smalls.
Is this the pegging thread? Always down for a good time.
Sent from my SM-G930V using Tapatalk
You guys are mean!
Just a bunch of "Peg teasers" !!!
EAP........
I'm relatively new, what is this all about?
Steven
2004 Marauder Black, loaded
Vortec S/C
4.10s
3500 PI Stall
Kook's headers
476.9 rwhp 385 lbs/tq
Lidio tune
2004 Suburban Dark Charcoal
I need a grommet. If I can't get one I guess I'll just have to sell the damn car.
Like in Wallace and Grommit?
....or is it missing a peg!?
A peg does not go there. Look at the lid....the alignment pin goes in that hole
