Another installment in the 'Historical Mercurys' Series!
427 Comet Cyclone Depicted.
Warning: The youtube car is a 'barn find', non running automobile.
https://www.youtube.com/watch?v=A3zsOsODQkg
Current Garage:
2005 Mustang GT Premium
2015 Triumph Trophy SE
― William W. Purkey
Man, I hope that they restore that Mercury Caliente!
That guy has a treasure trove of old FORD big block parts!
BTW: I've seen this locally owned Comet 202 Sedan 'R' code at several shows....
http://www.mustangandfords.com/featu...mercury-comet/
Current Garage:
― William W. Purkey
Nice series!
First retailed 2003 Marauder
Bought 6 June 2002
#168
