Just picked up my first Marauder. AC didn't work and nothing came out of the vents (at any fan speed). Going through this before with my Grand Marquis, I grabbed a new blower resistor motor. Yay got air coming out of the vents again. Crap only defrost though. Grabbed some flurosilicone 007 size O-rings and much to my surprise I still only have air coming out of defrost?
I switched the EATC from my GM which had the same O-rings replaced and voila - I have air from all vents again. Do EATC just go bad? Ran self-test. No codes? I'm stumped. Before I buy a new one, I just want to make sure there isn't something else I should be trying? It has to be the EATC itself since I switched it with a working unit and it solved the problem. Thank you in advance.
