MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Power Adders
Power Adders Look here for all your centrifugal, roots, supercharger, turbocharger and nitrous technical discussions regarding the Marauder!
Reply
Thread Tools Display Modes
  #1
Old 10-10-2018, 05:35 AM
montazch's Avatar
montazch montazch is offline
Senior Member
Trader: (0)
Lower End of an Eaton Swap
Hello all. I've searched out here for about a half hour and my time is running short.
I am putting in the bottom half of the Eaton. The Top is still for sale. Anyway, I'm trying to get the cooling tube to fit correctly so my lower intake will sit properly. I have both a new Marauder cooling tube and a new Cobra cooling tube.
Will someone please point me in the right direction as to how to install the cooling tube so my lower intake will sit down properly. BTW, I'm not a fan of "smashing" or "hammering" the Marauder cooling tube until "it fits".
Thanks all!!! Have a great day!
__________________
2004 DTR Marauder - Mods in the works.
Born-05 January 2004
#1253 of a build of 3214
#400 of 980 manufactured in Dark Toreador Red
  #2
Old 10-10-2018, 05:48 AM
Curless's Avatar
Curless Curless is offline
Senior Member
Trader: (13)
If you look through some of Zack's posts, you'll find that there is some grinding that needs to be done on the lower intake to make it sit flat. I can't post pics on the site otherwise I'd post em up. I also have a thread on my Facebook page that shows my install on my car. Curless Auto Repair, go to photos, go to Marauder Boost I believe is the name of the album... I have step by step photos.
__________________
#2941 300A
4.10's, carbon clutches
Marty O Tune
Curless Cure
Widened Wheels
Dead Pedal
Eaton Swapped
Bar tender and maker of:
Christmas in a cup
One Legged Lesbian Kickboxer
Cocka Two
  #3
Old 10-10-2018, 06:26 AM
montazch's Avatar
Senior Member
Trader: (0)
Cool Thanks!
Thank you very much!!!
__________________
  #4
Old 10-10-2018, 06:55 AM
musclemerc's Avatar
Senior Member
Trader: (27)
I assume the cooling tube is the one in the valley? If so use the cobra tube and remove the knock sensor, then grind down the knock sensor boss till the intake sits flat.
The knock sensor then relocates to the back of the cylinder heads.
  #5
Old 10-10-2018, 10:51 AM
Maraudermike1's Avatar
Maraudermike1 Maraudermike1 is offline
Member
Trader: (0)
I just did this last week and I had to smash the tube as well as grind the manifold. Be careful when grinding. Don't be a dummy like me and grind through the manifold! I had to make a repair weld.
__________________
-2003 Marauder Black 300A Eaton swapped
-2003 Redfire Mustang Cobra Convertible VMP Gen II
-2007 GT500 VMP Gen II
-1990 Fox Notchback. HCI/Supercharged
-1995 Thunderbird SC
-1996 Bronco 460 EFI Conversion. 9" Lift 35" BFG
-1999 F350 Super duty 7.3
-1989 Lesabre T-type
-2007 Cadillac DTS
-2012 Cadillac Escalade
-2015 Challenger Hellcat Sublime green A8
  #6
Old 10-10-2018, 12:04 PM
loud2004marquis's Avatar
loud2004marquis loud2004marquis is offline
"Flyin Brian"
Trader: (2)
^^^what musclemerc said^^^
Did the same on my swap
__________________
  #7
Old 10-10-2018, 04:44 PM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
Speaking as a plumber.. You are changing nothing but the shape of the tube by slightly ovaling it. Flow remains the same.
__________________
  #8
Old 10-10-2018, 06:13 PM
mm svt mm svt is offline
Senior Member
Trader: (0)
^^^ what he said,
The cobra one goes to the driver side
Iíve got four of the cobra ones if interested
  #9
Old 10-10-2018, 07:56 PM
musclemerc's Avatar
Senior Member
Trader: (27)
Sorry fellas but I disagree with smashing a steel tube, with a hammer, under an intake, and expect it to last. Flame suit on
Too much stuff to remove to replace! Besides, the OP said he has both a stock MM and a Cobra tube.
Use the cobra tube and be done with it! Done right or not done at all.
  #10
Old 10-11-2018, 02:30 PM
Senior Member
Trader: (0)
The process is explained in the trilogy installation instructions (not that it makes it better). Grinding on the bottom of the intake till you see light is a big mistake Iím glad I didnít make.
  #11
Old 10-12-2018, 11:35 AM
justgod's Avatar
justgod justgod is offline
Senior Member
Trader: (0)
Use the Cobra tube like musclemerc said. Hereís some random pics I just happened to take of both tubes laying in the valley:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
For Sale Marauder upper and lower intake, Eaton swap parts, ect Mackdombles Marauder-specific Parts for Sale 5 11-19-2017 07:49 PM
THIRD PARTY Lower intake eaton swap 200 lji372 Third Party Ads (Craigslist/eBay) 3 08-14-2014 09:54 AM
For Sale Eaton swap parts: intercooler, lower intake, water adapter tdotcv Marauder-specific Parts for Sale 4 02-18-2013 05:48 PM
Cheap lower intake for eaton swap loud2004marquis Power Adders 1 12-22-2012 04:08 AM
For Sale for sale lower intake and intercooler for eaton swap slick rick Marauder-specific Parts for Sale 23 02-12-2012 07:27 PM
Powered by: vBulletin
