MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 10-10-2018, 05:56 PM
Greg Greg is offline
Senior Member
Trader: (0)
Marauder Resurection Story
It has been awhile since posting but I have an update to my Marauder story.
It started this last winter after I purchased the Marauder. First was the inspection - suspension issues and missing front cats.
- replaced the entire front suspension including nearly new take off OEM springs (Joe Walsh)- figured why not just do it all.
- parking brake did not work - replaced rear brakes
- Aftermarket Radio would go in and out - turned out it was the unit so replaced
- Installed OEM front cats (thanks Joe Walsh)
- Posted that I had a ticking sound in the engine. Couldn't figure it out so decided to send it to Marty for a look see.
- Just before sending it to Marty steering, started going in and out. Couldn't figure it out and frustrated by this point so put it on the list for Marty.
- Wife complained about smell since previous owner smoked in the car. I can't smell that well so missed how bad it was.
BREAK ______________________________ _
- Got it to Marty.
-Turns out the #4 cylinder had a small hole in it. So, rebuild by Marty.
- Steering turned out to be a bad steering shaft
- Marty convinced me to go to 4.10 gears with tune. He also knew I would eventually get the big brake kit done as well. I did.
- Hood had the pop out/cut issue so Marty had that painted along with some other sections painted for me.
Flew down with my son and picked up the practicaly new Marauder. Very nice drive home big smiles
Break _______________________
Deal with smell next. Decided to just strip the whole interior except the dash.
- New head liner (bought one from a member and had it covered)
-bought some used visors
-bought a used overhead console
-replacement carpet
-lots of ozone treatments (works wonders)
While it was stripped, I decided to go all out and installed dynamat and dynaliner throughout the interior and trunk. This was a lot of work.
Nearly done. Just need a little more material for the trunk.
Just as I got it all back together and could drive again, the blower for AC/heater stopped working. Very frustrated at that point as I have been going at this car for a long time. Took fuse out and switched with another and it worked. Put the original back in and still works - don't know.
So, I am now basically done and enjoying my new very quite daily driver Marauder.
Thanks to Marty and all those that got me to this point.
Now that it is so quite I hear a whistle sound coming from the engine. Will post seperatly that issue.
Tried to keep it short - but I am really enjoying it now. As I said to Marty during this whole process, I went down the Marauder rabbit hole. But, I am coming out happy.
  #2
Old 10-10-2018, 06:32 PM
Joe Walsh's Avatar
Joe Walsh Joe Walsh is offline
STILL N/A
Trader: (7)
Awesome Greg!
Glad to hear that your Marauder is back in tip top shape.
It must be quiet as a tomb with that DynaMat.
What was wrong with the #4 cylinder?
__________________
2017 Ford Fusion Sport DFI. Twin Turbo V6 6 speed Auto
1985 Mustang GT 5.0 Hatchback 4bbl 5 speed manual
1999 Ranger 3.sl0w DD/Beater
  #3
Old 10-10-2018, 07:30 PM
Senior Member
Trader: (0)
The piston had a small small hole near an edge if I remmember correctly.
  #4
Old 10-10-2018, 09:24 PM
Chi Stallion's Avatar
Chi Stallion Chi Stallion is offline
Senior Member
Trader: (0)
Glad to hear you got it running again !!!!
__________________
300A 8-20-02
Webasto Aftermarket Moonroof
Rear Spoiler
S55 Tail Light Treatment
5% Limo Tints
Fresh Black Paint Job 11/11/2011
Stainless Works Headers & Full Exhaust System, Magnaflow Mufflers, Martyo Tune, JLT CAI & Catch Can, J-Mod, Rebuild 4R70W, Dynotech 4' 6061, Forced Lube Mod, EMP Stewart WP, Steeda UDP, 31 Ford Spline Axles, 31 Cobra Carrier w/CF Clutchs, Ford Racing 4.10 & M-4210-C3 Master Kit, TA Girdle & Stud Kit, Carfixer Alignment, Gorilla Lock, Cooper Zeon RS3A Tires, Metco Control Arms & Watts Link, Addco F/R Sway Bars, E/S Bar Bushings, Monroe Severe Shocks, SS Brake Lines, Napa Adap1 Brakes & Ultra Prem Rotors, AM Digital Oil & Volt Gauge, DDM HIDS 5K h/l & Fog Lights 5K, Full LED Upgrade, Alpine IVA-W505/P1, PKG-M780 Headrest Monitors, PXA-H100 Imprint, MRP-F300 4 channel, Rockford Fosgate 1501BD, SPR-60C & SPR-60 Speakers, HCE-C1100 & KTX-C10LP Camera System, Viper 5901 & VSM350 GPS SmartStart System, Yellow Optima, BIG III & 200 Amps Alt
  #5
Old 10-10-2018, 10:49 PM
crownvic97's Avatar
crownvic97 crownvic97 is offline
Senior Member
Trader: (4)
I have really enjoyed following your progress, you never gave up on the car and hopefully now you will be rewarded with many miles of trouble free performance!
  #6
Old 10-10-2018, 11:24 PM
Invective's Avatar
Invective Invective is offline
Supporting Member
Trader: (4)
Arrow
Quote:
I'm an ex-smoker so a faint smell wouldn't bother me. The odor will go away eventually when using Febreeze or something similar on a regular basis. I burned a breakfast biscuit in my microwave a few months back - took a month to get the odor out of the house and another month to get it out of the microwave!
Previous owner of my car was a smoker but he never smoked in it as far as I could tell. He had been using the OEM ash cup in another vehicle and handed it to me during the sale - I washed it out with Ajax Lemon Fresh Dish Detergent not long after arriving home - looks and smells new.
Care to share with us your spending? In general terms of course.
__________________
Current Garage:
2004 DTR Marauder
2005 Mustang GT Premium
2006 Ranger XLT Extended Cab 4 Door 4.0L 4WD
2008 Triumph Sprint ST
2015 Triumph Trophy SE
Whatever you can do, or dream you can, begin it. Boldness has genius, power and magic in it. Johann Wolfgang von Goethe
  #7
Old 10-11-2018, 03:16 PM
Turbov6Bryan's Avatar
I miss whitey here
Trader: (5)
My DTR was used as a ashtray from the previous owner, i used tea bags and a friend gave me some oil spray to get rid of smoke smell "for weed users i guess they know everything".. I just used the spray once and tea bags are still in it.
The smell is gone.
Good to hear yours is back on the road. FUN cars!
__________________
04 DTR
03 Black 300A
03 Black 300A
03 C.V. Sport Silver Frost
04 Supercharged SILVER BIRCH
04 SILVER BIRCH NA
  #8
Old 10-11-2018, 03:25 PM
ChiTownMaraud3r's Avatar
ChiTownMaraud3r ChiTownMaraud3r is offline
Back to Ridin' Clean
Trader: (3)
Looks great, do you know how much dynamat was necessary for interior and trunk?
__________________
'04 Eaton swapped Marauder #357 of 3213 - "MERCD U"
'15 Mustang GT PP (Second garage queen)
'03 GrandMa (Daily)
'08 Kawi ZX6R (Panty dropper)
  #9
Old 10-11-2018, 04:11 PM
NorthShoreChiMM's Avatar
NorthShoreChiMM NorthShoreChiMM is offline
Mike
Trader: (0)
Quote:
Interested as well, I commute everyday 90+ miles and the noise is much more noticeable at highway speeds, drowns out the great sound of the sound system
  #10
Old 10-11-2018, 05:05 PM
Senior Member
Trader: (0)
I bought three of the dynamat mega packs.
http://www.dynamat.com/dynamat-xtreme-mega-pak/
That should be enough to do the roof, interior, doors (outside and inside skin) and trunk. I came up just barley short. If I was more efficient I would have made it.
I also did dynaliner on the roof, door panels (took off the felt because it smelled), behind the seats, transmission tunnel, etc. It took a lot of boxes to do it all. I had to use the liner behind the back seats because the existing felt/rubber matt smelled.
If you don't have the smell issue, I would probably just put the 1/4" liner on the roof on top of the dynamat. It made a big difference there.
The stereo does sound a lot better.
Took me many hours to complete. But, I know how to take all the interior apart now. Hopefully will never do it again.
  #11
Old 10-11-2018, 05:14 PM
Senior Member
Trader: (0)
For those that are wondering about the carpet. Everybody gets them from the same place (Auto Custom Carpets - ACC). It is not OEM.
Stock Interiors (distributer)
ORDER DETAILS:
Item: 13232
Quantity: 1
Description: '03-'06 Mercury Marauder Molded Carpet 4 Door, With heelpad
Color: 8945-Ebony Plush Cut Pile
Backing: MassBack - 58.00
13232 - 137.95
Price (each): 195.95
Item Total: 195.95
No complaints on carpet. Slightly darker but very close. I used some additional dynapad under the foot areas and 1/2" dynaliner in other areas. The OEM has more felt (jute) then the replacement. Got it in less than 2 weeks.
If you just want to dynamat, you can reuse your carpet. It comes right out - not glued.
  #12
Old 10-16-2018, 06:53 PM
Taemian's Avatar
Taemian Taemian is offline
Trilogized by RC_Signals!
Trader: (2)
Wow, that's quite an investment with 3 packs. Hope it's very quiet now!
__________________
Lidio's Xcal2 flash, JLT CAI
Trilogized June/08 (mostly installed by RC_Signals)
Added: SW Long tube Headers + High Flow Cats
New BFGs (Best Baby Shower gift EVER!)
** New Best**
12.81@107.78 Oct 02/09
Ventilated Block Mod
Out of commission
Rebuilt with:
Teksid block/ForgedInternals/Melling oil pump/Canton windage tray/Rebuilt heads with SVT Cobra cams/Cloyes gears/ SVT Lightning MAF/Accufab TB/ MuscleMerc rear head cooling kit/ Steigy lightly ported and polished Eaton 112
  #13
Old 10-16-2018, 07:12 PM
Senior Member
Trader: (0)
It is quiet and the stereo sounds better. Finished the trunk this weekend. Done
The carpet is from a crown vic. Removed the CD changer (don't use with new radio). Fits pretty well. But, the right side has a bulge that I don't know what it is there for.
The sound material investment is only a small part of me going way over what I should have spent. I shouldn't be anybodys financial advisor.
  #14
Old 10-16-2018, 07:18 PM
Senior Member
Trader: (0)
Local car show - new and old
Bonus GTR Nismo
  #15
Old 10-16-2018, 07:39 PM
Joe Walsh's Avatar
STILL N/A
Trader: (7)
Nice! ...Your Marauder is looking great!
Burtonsville 'Church of the Holy Donut'.
I saw that 428 4 speed S55 over there a few years ago....what a sweet survivor!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Unexpected Marauder story Gccch Community Discussion 5 04-04-2015 08:46 AM
New Marauder Headlights...And a quick story... sflrainmaker01 Community Discussion 39 12-28-2013 07:14 PM
My Marauder Story junior Community Discussion 11 10-06-2013 04:14 PM
Powered by: vBulletin
