MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 10-10-2018, 06:03 PM
Greg Greg is offline
Senior Member
Trader: (0)
Engine Whistle
I am now hearing a slight whistle sound after letting off on the throttle. Under excelleration and constant speed there is no sound. It is a high pitched by very slight whistle sound. I can really hear it now since the interior had sound deadening installed.
I think I tracked it down to the part in the attachment. With a mechanics scope touching the metal ring it is more prominant.
What is this part and how difficult to replace? It looks like there is a pipe coming off the back that could make it more difficult to replace.
Thanks
  #2
Old 10-10-2018, 06:30 PM
Phrog_gunner Phrog_gunner is offline
Senior Member
Trader: (4)
I think Bubb Rubb is the expert on this issue.
__________________
  #3
Old 10-10-2018, 07:21 PM
mm svt mm svt is offline
Senior Member
Trader: (0)
The exhaust gas regulator/ EGR. Could just be a leak at the big nut.
  #4
Old 10-10-2018, 09:29 PM
Ambitious1's Avatar
Ambitious1 Ambitious1 is offline
Senior Member
Trader: (9)
This is the EGR (Exhaust Gas Recirculation) Valve. Very easy to replace. I just replaced mine two weeks ago. It only took ten minutes. First, make sure all the hoses are secure and it's not something simple like a loose hose. If you have to get a new OEM one, it's about $190 at Tasca Ford or $100 at Rockauto.com. Aftermarket stores like Advanced Auto and NAPA will have it for $150.
https://www.tascaparts.com/oem-parts...Y4LWdhcw%3D%3D
https://www.rockauto.com/en/catalog/...egr+valve,4968
https://shop.advanceautoparts.com/p/...Term=EGR+Valve
  #5
Old 10-10-2018, 09:31 PM
Ambitious1's Avatar
Senior Member
Trader: (9)
This is a decent video with step-by-step instructions on how to replace the EGR valve:
https://www.youtube.com/watch?v=r98kyXmME1Q
  #6
Old 10-11-2018, 02:40 AM
Senior Member
Trader: (0)
That video is very helpful. Hopefully that bolt will come off easily. Would this have had to be disconnected during the engine rebuild? If so, perhaps it won't be too bad since it has been only a couple of months and not very many miles.
Guess I should check to make sure the bolt is tight first before replacing.
I think I am right about the whistling location - has anybody else found this to be the case?
Thanks
  #7
Old 10-11-2018, 05:31 AM
Ambitious1's Avatar
Senior Member
Trader: (9)
I am assuming that you had the upper intake manifold taken off during the rebuild, so yes you probably had the EGR valve disconnected / removed as well.
  #8
Old 10-11-2018, 07:18 AM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
The pipe could be seated incorrectly. Loosen big nut, then remove the two bolts holding the EGR. Walk the nut off and make sure the threads are good, then walk it back in and hand tighten. Reinstall the two bolts, then tighten nut.
If you attempt to just install the tube without having the EGR very loose it will cross thread and/or just complicate an easy job.
__________________
  #9
Old 10-11-2018, 07:19 AM
justbob's Avatar
Sick-Speed play toy
Trader: (11)
Quote:
Can I get a woooo WHOOOO?
__________________
  #10
Old 10-11-2018, 07:43 AM
Senior Member
Trader: (0)
Thanks much. Will let you know what I find when I get a change to work on it.
  #11
Old 10-12-2018, 08:46 AM
1Marauder's Avatar
Senior Member
Trader: (5)
Awesome assist!
__________________
Tune, JLT, FlowMaster 42441 Res Delete, New Nitto 235/255 Bigcarsforever dead peddle & custom SRP peddles, 5 coats Zymoil Titanium, Addco front and rear sway bars, KYBs, 1/2 inch coil cut, Sparts Watts link and Control Arms, Carfixer alignment.
2003 CV Sport Matador Red, 19,280 Miles, DD, Curless Full Service Royal flush, Marto Tune, 18 Chrome Wheels w 235/265 front/back Nitto tires, Monroe Severe Duty Shocks, Carfixer Alignment
2004 CV HPP Silver Birch, 93,000 miles. Son's DD, 18 Chrome Wheels w 235/265 front/back Nitto tires (thank you Lowdex!)
  #12
Old 10-14-2018, 11:50 AM
Senior Member
Trader: (0)
1/8 of a turn of nut. Problem solved. Thanks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
The death whistle Black_Noise The Lounge 6 01-12-2013 01:29 PM
Whistle while you work cruzer Shop Talk 7 01-27-2011 06:46 PM
Whistle noise form engine compartment tjl006 Shop Talk 23 08-02-2010 06:19 AM
Deer Whistle????? sailsmen The Lounge 25 12-07-2007 06:20 PM
Whistle sound Ed Tarras Shop Talk 11 02-22-2007 09:52 PM
Powered by: vBulletin
