Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: Back-up lights illuminated entry
    Aug 2009
    Somerset, England
    Cool Back-up lights illuminated entry
    Hi Guys
    I've noticed a lot of the newer vehicles put the back-up lights on when the trunk/tailgate is opened or with the illuminated entry feature when the car is unlocked and thought I might have a go at reworking the back-up lights on my Marauder to do the same.
    So the design brief was for the back-up lights to come on when the trunk is open and as an illuminated entry feature when the car is unlocked at night and the parking/head/courtesy lights come on.
    At first I thought it would be a simple job with a couple relays but I ran into a problem, the trunk light ground wire has voltage on it from the LCM untill switched to ground when the trunk is opened, which basically meant I had to add an extra relay, here is my wiring schematic for you to critique.
    There is one minor fly in the ointment I am working on at the moment and that is the courtesy lights fade as they turn off which means the upper right relay coil loses voltage gradually and buzzes for 1/2 a second as it trys to switch with a low voltgae, as the relay is buzzing it means the contacts will be arcing, not a good thing for relay longevity, I am thinking this may be cured with a capacitor across the relay coil.
    Regards
    Dereck
    Sep 2010
    Western WA
    Having a capacitor in the system to provide that fade away effect is what is causing the problem of the buzzing relay adding another will only extend the time that the relay buzzes.
    Sep 2008
    B'lo, NY
    How about using a solid state relay? Low power ones can be purchased for pretty cheap. Im gonna run this plan past my electrical engineer friends and see if we cant solve the noise problem.
    Your diagram looks good to me. I like where your head's at with this idea.
    To do list:
    Sep 2008
    B'lo, NY
    Are the parking lighs always on when driving at night with the headlights? The only problem I see with that diagram is if I turn the dome light on while driving at night, the reverse lights will come on. Not good.
    To do list:
    Aug 2009
    Somerset, England
    Thumbs up
    Hi Emas
    Quote Originally Posted by EMAS View Post
    I was thinking maybe reduce the relay coil voltage to a minimum required for the coil to hold using a resistor and then a capacitor would maybe reduce the "buzzing" with a little extra voltage before the voltage drops off completely as the courtesy lights fade
    Hi Dmjarosz
    Quote Originally Posted by dmjarosz View Post
    Yes the back-up lights would come on if you switched the dome lights on while driving at night but this would only happen if you used the main light switch to do it, which I expect you would virtually never need to do as the rear seat passengers can switch thier dome/reading lamps on indipendently and the front seat passenger/driver can switch thier light on using the switch in the roof console.
    Regards
    Dereck
    Sep 2010
    Western WA
    Where in the circuit are you planning to put the capacitor and resistor?
    Aug 2009
    Somerset, England
    Hi Emas
    The resistor/capacitor thought has been shelved due to calculations revealling an unfeasonably large capacitor would be required, plan B is to use a Schmitt trigger and then maybe making the whole circuit solid state.
    Regards
    Dereck
    Sep 2008
    B'lo, NY
    Quote Originally Posted by Dereck View Post
    I use the main switch to do it all the time. What about some sort of normally-closed relay on the dark green wire in your diagram that opens when the car is shifted out of park? That would prevent the reverse lights from coming on when the car is moving. Is there something on the transmission circuit that could be tapped?
    What newer vehicles do you see that have this feature? It would be nice to get a wiring diagram and see whats going on from the factory.
    To do list:
    Sep 2010
    Western WA
    GMs are the ones I've seen with that feature.
    May 2009
    Moreau Island
    Wouldn't it be easier to just add a few more courtesy lites around the car and have them come on with the push of the unlock button?
    I would think the added glare from reverse lites would make rummaging around in the trunk a pain. Might be better to just add some extra lites in the trunk for rummaging. JM
    When the trunk lid is open the reverse lights are pointing up. How will that help with looking in the trunk or lighting up around the rear? Would be much easier to add LEDs to the inside of the trunk and maybe some under the rear bumper.
    May 2009
    Moreau Island
    Not exactly......
    May 2009
    Moreau Island
    Not exactly......
    Pretty darn close.
    That's actually what I was thinking. Most modern vehicles now, the reverse/back up lights are part of the body or taillights that are affixed to the sides of the trunk/lift gate.
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
  1. Tail lights and back up lens
    By Flynlow in forum Community Discussion
    Last Post: 04-17-2012, 07:01 PM
  2. tinted back up lights
    By -Matt- in forum Community Discussion
    Last Post: 08-10-2009, 05:37 AM
  3. Back-up lights
    By jimlam56 in forum Community Discussion
    Last Post: 11-10-2005, 05:21 PM
  4. Door Panel Entry Lights
    By NavHeliRescue in forum Shop Talk
    Last Post: 04-24-2004, 07:17 PM
  5. Back end lights & Trim ?
    By jaywish in forum Shop Talk
    Last Post: 09-30-2003, 03:21 PM
