MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > Marketplace > Other Parts for Sale
Other Parts for Sale Trying to sell an accessory or part? Post it here!
Reply
Thread Tools Display Modes
  #1
Old 06-19-2018, 02:38 PM
SteelQualityMan's Avatar
SteelQualityMan SteelQualityMan is offline
60's Street-Strip Racer
Trader: (1)
Post AFCO 80284PRO HEAT EXCHANGER
More from the depths of my garage : 80284PRO heat exchanger for 2010-up Supercharged Ford Raptors and F-150. AFCO Racing Products 80284PRO offers increased surface area, volume, and a double pass design to reduce and stabilize coolant temperatures by as much as 30F over stock part. The 80284PRO comes with dual 10-inch SPAL fans which can move over 1600 CFM of airflow (800 CFM per fan) through the massive heat exchanger.
Specs:
Overall Width: 26"
Inlet Size: .75"
Overall Height: 15"
Outlet Size: .75"
Overall Thickness: 5"
Tube Style: Cross Flow
Core Width: 22.38"
Radiator Style: Double Pass
Core Height: 15"
Row Quantity: Dual
Core Thickness: 2.25"
Material Type: Aluminum Natural Finish
Inlet Location: Upper Right
Outlet Location: Lower Right
Dual 10" SPAL fans 808 CFM each
Dual SPAL thermostatic relay wiring harness
With dual relay wiring harness this unit retails for $799.99 on all major supplier's (Jeg's, Lethal Performance, Summit Racing, Ebay) web sites. I am including an upgraded wiring harness (From $60 to $90 retail) that will let you control the two fans independently.
This unit is in NEW Condition. It was used as a display so there are two extra mounting points on the bottom. The original factory box was opened for inspection and photography. The unit was re-packed in the factory box, which is how it will be shipped to the buyer.
Garage Sale Price: $500 plus the ride or make me a reasonable offer This part moves to EBAY on Monday
You don't need a Raptor to use this unit I was planning to use it as a cheaper alternative to a Killer Chiller in my Crown Vic project, then upgrade later on.
File Type: jpg This one---Afco dual pass intercooler.jpg (124.3 KB, 38 views)
File Type: jpg SPAL DUAL relay harness & Thermostat-1.jpg (9.8 KB, 35 views)
__________________
  #2
Old 07-14-2018, 12:25 PM
Trader: (1)
Bump for RADICAL price cuts / Weekend Special
__________________
  #3
Old 08-10-2018, 06:23 AM
Trader: (1)
Cool
Quote:
Specs:
Overall Width: 26"
Inlet Size: .75"
Overall Height: 15"
Outlet Size: .75"
Core Width: 22.38"
Core Height: 15"
Row Quantity: Dual
SOLD on EBay. You missed a great deal folks.
__________________
  #4
Old 08-10-2018, 08:29 AM
Spectragod's Avatar
Spectragod Spectragod is offline
Willing to meet up half way
Trader: (45)
I'll agree it was a deal, but, you have people that are 8-10th generation owners and bought their Marauders for Crown Vic money, a tune is an "expensive" mod and that's about where it stops.
Had I needed that unit, I would have got it jammed in my car, but it wouldn't have been an upgrade at this point.
__________________
When you are dead, you dont know you are dead. It is difficult only for others. It is the same way when you are stupid.
Trilogy # 192 / T.S. 0012
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Heat Exchanger Options sparky1562 Power Adders 0 04-01-2014 05:56 PM
New heat exchanger Blown3.8 Power Adders 19 07-21-2012 04:45 PM
For Sale heat exchanger bugsyc Other Parts for Sale 15 11-03-2011 07:25 AM
For Sale OEM Cobra Heat Exchanger FordNut Other Parts for Sale 10 09-25-2011 01:18 PM
Lightning Heat exchanger For MM'S MarauderMark Trilogy Motorsports 3 03-22-2005 12:15 PM
Powered by: vBulletin
