MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Tuning
Tuning This forum is to exchange information about tuning and tuners.
Reply
Thread Tools Display Modes
  #1
Old 12-06-2015, 06:12 PM
Blown3.8's Avatar
Blown3.8 Blown3.8 is offline
Mr. Hankey
Trader: (2)
Free Tuning Software
There is now free software available to tune virtually any 99-04 ford vehicle, including your marauder. All you would need to buy is a Moates Quarter Horse and a laptop. Then download Tuner Pro RT and the definitions and stock tune file from efidynotuning there is lots of good "how to" on efidynotune too. Here is a getting started thread http://www.efidynotuning.com/started.htm
What this setup allows you to do over sct is, live tuning. You do not need to turn the car off to make a change to the tune. It is the greatest thing in the world.
I'm still looking for the base marauder tune on efi's site, but I plan to start playing with this soon.
__________________
~Chris
  #2
Old 12-06-2015, 06:26 PM
Turbov6Bryan's Avatar
I miss whitey here
Trader: (5)
Nice! Would be nice for forced inducted marauders, tie in the wide band, tell it to maintain 11.2:1 air fuel and tuning it within minutes.
Turbo tweak does this for our buicks
__________________
04 DTR
03 Black 300A
03 Black 300A
03 C.V. Sport Silver Frost
04 Supercharged SILVER BIRCH
04 SILVER BIRCH NA
  #3
Old 12-06-2015, 06:30 PM
MOTOWN's Avatar
MOTOWN MOTOWN is offline
S/C 20" MINI TUBBED WHEEL GUY!
Trader: (48)
Why in the world would you want to maintain an afr that rich
__________________
ITS ALIVE !!!!!!!!
STAY TUNED!!!!!!!!!!
  #4
Old 12-06-2015, 06:38 PM
03sport007 03sport007 is offline
Senior Member
Trader: (0)
Does this allow you to change the shift and lockup schedule?
__________________
03 SB 300B
Eaton Swap Tuned by Fast Specialities
Trans rebuilt by Darin at BC Automotive with a Triple Disc 11in Circle D TC. Tuned by Zack. The man that made my Marauder fun again.
4.10 gears with Cobra clutches. No more one wheel peel
Metco Drive Shaft Loop.
Next bigger brakes!!!!
  #5
Old 12-06-2015, 06:40 PM
I miss whitey here
Trader: (5)
10.8 is rich
11.2 - 11.4 is just right on the buicks with methanol, remember we have 8.5 compression and run 25-35 psi on pump gas and meth
What do you tune for on the marauders with forced induction?
__________________
04 DTR
03 Black 300A
03 Black 300A
04 SILVER BIRCH NA
  #6
Old 12-06-2015, 06:42 PM
MOTOWN's Avatar
Trader: (48)
10.8 is rich
I thought you were talking about the Marauder, not the GN.
__________________
ITS ALIVE !!!!!!!!
  #7
Old 12-06-2015, 07:03 PM
I miss whitey here
Trader: (5)
Quote:
I commented on your thread where you made some awesome amount of power! hope you don't mind me bringing that picture here
Sure looks like 11.4 on your car too , or at least that's what they were trying to get it to.
I still say it needs more fuel above 6200. I consider 11.8 or higher lean, but then again the marauder has aluminum heads
Imagine setting your direct drive target air fuel and it never varies from that.
Just like running a FAST system. Set it, tune it and your done, if something goes wrong the computer can add up to x amount more fuel
__________________
04 DTR
03 Black 300A
03 Black 300A
04 SILVER BIRCH NA
  #8
Old 12-06-2015, 07:30 PM
MOTOWN's Avatar
Trader: (48)
No i dont mind at all, thank you, i like exactly where Jeff has the AFR through the power band , and 11.8 isn't lean , and yes the Marauder has aluminum heads, and block.
__________________
ITS ALIVE !!!!!!!!
  #9
Old 12-06-2015, 10:51 PM
lifespeed lifespeed is offline
Senior Member
Trader: (1)
Good find!
__________________
Lifespeed
  #10
Old 12-07-2015, 06:10 AM
Zack's Avatar
Zack Zack is offline
Turbo Marauder
Trader: (40)
The majority of SC Marauders run best at 11.2-11.4 AFR
Anyone saying that is not a good target AFR is silly
  #11
Old 12-07-2015, 03:09 PM
Blown3.8's Avatar
Mr. Hankey
Trader: (2)
Added info to first post. Download tuner pro rt and then added a getting started link
__________________
~Chris
  #12
Old 12-07-2015, 03:52 PM
Logizyme's Avatar
Logizyme Logizyme is offline
Senior Member
Trader: (2)
Have you used this with success on a Marauder? Looks like that Montes hardware is for EEC equipped cars - more for pre-OBD2 by the looks of it.
__________________
  #13
Old 12-07-2015, 06:13 PM
Blown3.8's Avatar
Mr. Hankey
Trader: (2)
I'm working on it. Waiting for my tune to get converted instead of starting from scratch to see if it works.
I have been using the QH for years on my tbird with the eec 4. And yes the QH is mostly used on the non OBD2 stuff so you could datalog without external sensors. But it will work on EECs with the chip port as long as someone creates the software files to decode the EEC strategies.
__________________
~Chris
  #14
Old 05-02-2016, 08:51 PM
Senior Member
Trader: (1)
Any updates on this?
__________________
Lifespeed
  #15
Old 05-03-2016, 09:56 AM
Blown3.8's Avatar
Mr. Hankey
Trader: (2)
He has moved from a mustang strategy to the Marauder strategies. Cause the Maruder EECs are more advanced. So that should make it a little more straight forward for us when he is done decoding it.
__________________
~Chris
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Opinions on tuning software MyBlackBeasts Tuning 20 01-16-2013 06:20 PM
Anyone using Sniper tuning software? juno Tuning 15 06-24-2009 08:31 AM
Sniper Tuning Software Rider90 Tuning 2 06-23-2006 02:20 PM
Kudos to the Superchips tuning software. 89lxbill Tuning 4 02-20-2004 06:20 PM
Jerry's Tuning Software via Superchips? MitchB Tuning 9 09-28-2003 10:05 PM
Powered by: vBulletin
