MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Tires & Wheels
Tires & Wheels Post your discussions about tires and wheels here!
Reply
Thread Tools Display Modes
  #1
Old 01-11-2018, 06:16 PM
NorthShoreChiMM's Avatar
NorthShoreChiMM NorthShoreChiMM is offline
Mike
Trader: (0)
Wider Wheels
Yes I know this has been discussed multiple times, each was for a specific instance, Yes I have read motowns post, and all the other ones. Im looking for preferably either 18x10 all around, or 18x9 up front and 18x10 rear. Im willing to add a spacer, I'm fine with the tires sticking out a small amount. My concern is people have different opinions, some say they rub with 18x10 rear, some say they don't. I DONT want the tires to rub at all, under any instance, I just don't want to deal with it. Please give specific specs, Wheel size, offset, tire combination, etc. Thank you. I appreciate all the info.
-Mike
  #2
Old 01-11-2018, 07:41 PM
Bad_S55's Avatar
Bad_S55 Bad_S55 is offline
63/40
Trader: (1)
I don't know what style you're really looking for, but I ran GT500 wheels for a while. 18x9.5 all around with a 255/45 up front & 285/40 in back. Could've gone wider, but I didn't care much at the time. GT500s come in other styles & sizes, namely 19x9.5 & 20x9.5
__________________
2005 Mercury S55
Saleen Series II Supercharger
Zack big brake kit with custom S55 calipers
Full Stainless Works Marauder exhaust system
Addco front & rear sway bars
Cut Marauder Springs with KYB Shocks
Spherical sway bar links
3.55 gears, trac-lok, and 31 spline axles
Tuned by Lidio at Alternative Auto
LX Sport/Marauder hybrid interior
LEDs inside & out
  #3
Old 01-12-2018, 05:17 AM
fastblackmerc's Avatar
Trader: (75)
Running 295/45's on widened rears. No problems at all.
__________________
  #4
Old 01-12-2018, 11:09 AM
Lowndex's Avatar
Lowndex Lowndex is offline
Middle Age Crisis Member
Trader: (3)
Google: "2004 Mercury Marauder widened wheels"
Also, related and interesting threads from our forum search:
https://www.mercurymarauder.net/foru...ad.php?t=54456
https://www.mercurymarauder.net/foru...d.php?t=105200
https://www.mercurymarauder.net/foru...d.php?t=105416
https://www.mercurymarauder.net/foru...widened+wheels
  #5
Old 01-12-2018, 11:52 AM
Mike
Trader: (0)
Quote:
What were the rims widened to and are you running a spacer. Thanks
  #6
Old 01-12-2018, 12:00 PM
Trader: (75)
No spacers and I believe they are 10" wide.
__________________
  #7
Old 01-12-2018, 03:07 PM
Blown3.8's Avatar
Blown3.8 Blown3.8 is offline
Mr. Hankey
Trader: (2)
For the rear an 18x10 with a +40 thru +50 offset would work good. The higher the offset number the more it will pull the wheel in. You want a max BS of about 7.5" I wouldn't go more than 7.75" BS.
For the front I don't know.
This website gives you a good visual of offset changes and different tire sizes. willtheyfit.com For the rear "I" think this size wheel fits perfect. 18x10.5 with a +48 offset. If you punch that info into the existing setup field then you can play with different wheel sizes you find to see where they sit. And a good tire size to input is 295 45 18 for a 10" wheel.
Some visuals of the 10.5 wheel with a 10.5 slick
[IMG]Race Star 3[/IMG]
[IMG]Race Star 2[/IMG]
__________________
~Chris
  #8
Old 01-12-2018, 03:22 PM
Turbov6Bryan's Avatar
meow meow meow
Trader: (3)
Typically folks do 1.5 inch wider so it doesnt rub.
You know this, but i would have thought you had 18x9.5
__________________
  #9
Old 01-12-2018, 03:28 PM
Blown3.8's Avatar
Mr. Hankey
Trader: (2)
And here is a visual of the 18x10.5 +48 offset wheel with a 10.5" wide slick on the inside.
Sent from my SAMSUNG-SM-G890A using Tapatalk
__________________
~Chris
  #10
Old 01-13-2018, 10:02 AM
sailsmen's Avatar
sailsmen sailsmen is offline
Supporting Member
Trader: (1)
Widths vary by MFG.
The Nitto NT05R DRAG 305/45R18 rub.
The MT 3786R P305/45R18 ET Street Radials didn't rub.
__________________
  #11
Old 01-13-2018, 11:35 AM
meow meow meow
Trader: (3)
Quote:
I know you said +48
What is the backspace of the rear?
__________________
  #12
Old 01-13-2018, 07:53 PM
Mike
Trader: (0)
Does the offset of the wheels have to change from stock when using 18x9.5 rims.
  #13
Old 01-13-2018, 08:20 PM
Blown3.8's Avatar
Mr. Hankey
Trader: (2)
I know you said +48
Race star advertises it at 7.63
Quote:
Yes. Offset changes when you change widths. Offset is a measurement relative to the centerline of the wheel.
I probably misread your question. A non stock wheel in 9.5" width with the stock offset of +50mm would fit well.
__________________
~Chris
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
wider wheels with same distance to outer fender MarauderPU Tires & Wheels 0 11-11-2012 06:41 PM
OEM Wider Wheels? bawazir Tires & Wheels 207 02-09-2010 09:05 AM
wider front wheels? highoctanecobra Tires & Wheels 18 12-24-2009 10:41 AM
wider rear wheels evillost@adelph Tires & Wheels 3 12-05-2006 04:20 AM
Wider rims Dennis Reinhart Tires & Wheels 7 10-14-2003 09:35 PM
Powered by: vBulletin
