Results 1 to 15 of 21
Thread: Whipple
    Mar 2010
    Myrtle Beach S.C.
    Question Whipple
    If alot of cobras with eaton superchargerers are changing over or upgrading to whipples, Why can't we go with a whipple fron the start?? On another site they say we can't use a whipple on a stock motor.True???
    IIRC, Jerry told me that certain parts had to be modified on the twin screw to make it work for the MM. I know the blower plate will need to be fabbed, as well as an adapter plate for the intake on the rear. I think he also said something about the snout length needing modified, but not 100% sure on that.
    Trilogy # 192 / T.S. 0012
    You can put a Whipple on. But you have to get all the rest of the Eaton swap parts too.
    ^^^^^ what Fordnut said ^^^^^
    One of the attractive aspects of the Eaton swap is lower cost (usually under $5,000, all-in). An Eaton M112 blower will cost you somewhere around $300 used, a new Whipple blower is prolly gonna cost between $4,000 - $5,000, plus the ancillary parts required to install it on your car. But other than the cost issue, it could certainly be done.
    For bolt-on and drive, the Trilogy kit is still the best option on the market, IMO.
    Jul 2009
    NH
    If you stick with a whipple upgrade for an 03/04 cobra and get the rest of the Eaton swap parts, not a prob.
    http://www.lethalperformance.com/sup...lished-p-35047
    12.073 @ 118.43 (Nitto 555)
    Drag racers prayer:
    Has anyone tried a Whipple kit designed for a MACH I?
    Essentially the same engine, so I would think this would be a complete bolt in except for the passenger's side intake/battery relocate.
    St Clair Shores, Michigan
    Is the difference between the eaton and whipple that drastic? I'm talking performance.
    2012 Jeep Grand Cherokee Laredo-White
    2012 Jeep Grand Cherokee Laredo-Silver
    2011 Ford Fusion SE
    Retired 2003 Mercury Marauder/Trilogy 054
    Retired 2004. 13.00 on Nitrous safely tuned by Alt Auto.
    Smoke Cloud
    Wink
    a new Whipple blower is prolly gonna cost between $4,000 - $5,000, .
    $3,379.99 2.3L whipple from sparta performance.
    Oct 2008
    Ocala, florida
    Quote Originally Posted by jstevens View Post
    Ohh yeah......
    North Aurora, IL
    Oh hellz to the mutha fkn yeazzzz!!!
    Sent from my iPhone
    Go White Sox!!!
    Great quotes!!
    Eat poo poo and die heathen.
    $5200 for a black 4.0 and $5600 for a polished. Oops, how did I know that right off hand?
    Quote Originally Posted by DOOM View Post
    Size matters....
    Oh yes it does! Plus I just broke the urban myth LOL!!!!
    Is there such a kit?
    I know the KB kit for Mach 1 uses a single belt for everything, similar to the centrifugals. That can be problematic.
    Jul 2009
    NH
    Besides being able to move air more efficiently/less parasitic drag with their twin screw design, the Eatom M112 is 112 cid or 1.83l. You can put a 2.3l to 4.0l, more effiecient, whipple on.
    Drag racers prayer:
  1. Whipple/Max boost!?
    By DOOM in forum Power Adders
    Last Post: 07-02-2011, 07:26 PM
  2. Hey MM BKK, Another 3.4 Whipple is on the Prowl
    By FordNut in forum The Lounge
    Last Post: 08-29-2009, 03:21 PM
  3. Here's what a Whipple can do:
    By Zack in forum The Lounge
    Last Post: 02-25-2009, 07:12 AM
  4. 04 DSS Lighting with Whipple
    Last Post: 02-11-2009, 11:06 AM
  5. Whipple Blower anyone?
    By Matt Johnson in forum Shop Talk
    Last Post: 04-16-2003, 04:21 PM
