MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Steering, Suspension & Brakes
Steering, Suspension & Brakes Post your discussions about steering, suspension, shocks, control arms and brakes here!
Reply
Thread Tools Display Modes
  #1
Old 12-06-2018, 10:51 AM
IndyMerc IndyMerc is offline
Member
Trader: (0)
Metco watts link difference
I just bought a used pair of metco's.
what is the difference between the air suspension option and not?
also one of the bushings has a crack on one side not all the way through, should i replace it?
was having a hard time finding which ones if i go ahead with the replacement.
File Type: jpg 47578848_2236624249917343_5967672984083628032_n.jpg (150.0 KB, 88 views)
  #2
Old 12-06-2018, 11:18 AM
blazen71's Avatar
blazen71 blazen71 is offline
I'm Your Huckleberry
Trader: (3)
The ones pictured are air suspension. They have the adjustable bracket for the height adjustment arm. I'd try contacting Metco for the replacement bushing.
__________________
2004 300A Procharger #0010 P1SC, now D1SC. Thanks Jack
2003 300A Procharger #0017 D1SC (SOLD)
  #3
Old 12-06-2018, 12:05 PM
fastblackmerc's Avatar
Trader: (75)
Quote:
What he said ^^^^^^^^^^^^^^^^
__________________
  #4
Old 12-06-2018, 10:24 PM
Member
Trader: (0)
so I lucked out then, my car has air suspension. got em used for 125. Thanks guys!
  #5
Old 12-07-2018, 04:47 AM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
Quote:
All Marauders came with air bags. And yes, you scored big time.
Call Rick or Christie at Metco. They will set you straight.
__________________
  #6
Old 12-07-2018, 06:04 AM
blackhueys's Avatar
blackhueys blackhueys is offline
424HP@412TQ/13.61@103 IN QTR
Trader: (0)
I have all metco in the back of my marauder if you need an pictures of how it goes together ask away. Not to bad of a job, pulling the tires helps. I did everything on the ground by myself in a day
  #7
Old 12-07-2018, 10:01 AM
Member
Trader: (0)
I was trying to decide on getting the matching upper and lower control arms. will they make as much of a difference? I prefer the look of the heinous upper and lowers, both seem pricey for what you get i suppose Ill end up going with them eventually anyway.
I was looking at the bell crank, or end links, basically the swivel that attaches the watts link bars together and onto the center housing itself that no one has a set name for it seems.
the stock one looks flimsy is there a clear choice for replacement on this?
I noticed it has bearings so that puts it on my replacement hit list automatically.
I am currently waiting to get my housing back from powdercoat so the 4.10's and trutrac with 31 splines can go in. 1" adco swaybar.
your help will be appreciated!
trying to figure out what 8.8 bracing can be done without interfearing with the suspension itself.
cro-mo brace and maybe another added on the keep the rear as stiff as possible since eventually a built 4.6 TT will get dropped in.
ill post updates in my rear end guidance thread when there is one.
  #8
Old 12-07-2018, 11:05 AM
blazen71's Avatar
Trader: (3)
The billet control arms make a huge difference off the line, highly recommend them. The billet Watts links are marginal unless you road race or drive in that fashion.
__________________
  #9
Old 12-07-2018, 12:02 PM
musclemerc's Avatar
Senior Member
Trader: (27)
OP,,,You got a deal
  #10
Old 12-07-2018, 02:05 PM
Gerry24's Avatar
Gerry24 Gerry24 is offline
Senior Member
Trader: (1)
In regards to the upper and lower control arms. The vendor here Sparta performance sells CHE upper and lower and look great in black. In addition, the price is a lot better than Metcos.
__________________
Righteous Indignation
03 300A
4055 of 7838
4054 of 7093 in Black.
Born 8/23/02
Adopted in 1/15.
  #11
Old 12-07-2018, 04:24 PM
1Marauder's Avatar
Senior Member
Trader: (5)
Yes you need both! Watts controls tail waggle... Which you can feel when closing door stearnly... Car tail will waggle a little. Install watts link and closing door feels like vault door (or older Mercedes).
Control arms will remove lag from right foot to rear wheels.
Combined it is almost unfathomable they didn't come this way from the factory.
You won't believe the deifference.
Yes do all new bushings while you are at it.
Just my .02...
__________________
Tune, JLT, FlowMaster 42441 Res Delete, New Nitto 235/255 Bigcarsforever dead peddle & custom SRP peddles, 5 coats Zymoil Titanium, Addco front and rear sway bars, KYBs, 1/2 inch coil cut, Sparts Watts link and Control Arms, Carfixer alignment.
2003 CV Sport Matador Red, 19,280 Miles, DD, Curless Full Service Royal flush, Marto Tune, 18 Chrome Wheels w 235/265 front/back Nitto tires, Monroe Severe Duty Shocks, Carfixer Alignment
2004 CV HPP Silver Birch, 93,000 miles. Son's DD, 18 Chrome Wheels w 235/265 front/back Nitto tires (thank you Lowdex!)
  #12
Old 12-08-2018, 05:02 AM
Member
Trader: (0)
I was actually looking for a bushing list, with part numbers. I want all Poly, Is out car the same as all crown vic's if I call energy suspension.
Ill get the uppers and lowers too then. Thanks for the input.
  #13
Old 12-08-2018, 06:17 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
get the bushings from Metco
__________________
  #14
Old 12-08-2018, 11:00 PM
stevengerard stevengerard is offline
Senior Member
Trader: (0)
here is an old thread, years ago there were lots of discussions about how much the watts link add to the handling of the car. I have yet to change that - but did change the control arms, those made a huge difference going in a straight line
https://www.mercurymarauder.net/foru...p/t-22816.html
__________________
Steven
2004 Marauder Black, loaded
Vortec S/C
4.10s
3500 PI Stall
Kook's headers
476.9 rwhp 385 lbs/tq
Lidio tune
2004 Suburban Dark Charcoal
  #15
Old 12-09-2018, 12:06 AM
1Marauder's Avatar
Senior Member
Trader: (5)
In other terms, after Watts link and rear upper and lower control arms, Car feels 800 pounds lighter, two feet shorter, 4 inches lower, and even 20hp more powerful.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Metco Watts Link Chi Stallion Steering, Suspension & Brakes 22 10-01-2014 03:33 PM
metco watts link tallpaul Steering, Suspension & Brakes 7 12-06-2012 09:02 PM
Hey Metco Watts Link Guys... Rider90 Steering, Suspension & Brakes 10 05-10-2007 05:34 PM
Metco Watts Link Installed Donny Carlson Shop Talk 7 04-24-2005 08:54 PM
Powered by: vBulletin
