Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: Opinions on hours charged for repairs
    May 2016
    T-Town
    Just looking for opinions on the total hours charged on work recently done on my Marauder.
    Timing chain guide kit installed.
    Oil pump replaced.
    Thermostat replaced.
    15 hours. I thought I was keeping costs down by having the oil pump and thermostat relaced while he was in there. Never would have guessed 15 hours.
    Opinions?
    Oh yea, $1350 in labor.
    Price seems cheap for bay area prices. Hour estimate seems high, however, and given the labor cost I would have expected a recommendation to replace other wear parts unless the chain was new and the guides were worn; which seems unlikely.
    May 2016
    T-Town
    Quote Originally Posted by ByronRACE View Post
    Everything was changed out. Guides actually weren't that bad. Went in for a timing chain oil leak and I requested all the repairs. Just was surprised at 15 hours. Thanks.
    t town is where? I dont understand why folks dont put a area up top?
    You got hosed on labor lol.
    A tube of the right stuff could have sealed it up j/k
    May 2016
    T-Town
    I'm in North Florida. To fix an oil leak....yes I got hosed but he did much more than that.
    Quote Originally Posted by Jtrip View Post
    You could have flown ZACK in to do it for about the same? IDK.
    At least its fixed correctly.
    Like it or not most all shops including myself when I did it charge book time.
    Timing chains - 6.7
    Oil pan - 6.6
    Thermostat - .9
    Total = 14.2 plus a little extra to R&R oil pump.
    Ford doesn’t actually give a book time on the oil pump, It just refers you to basically a new engine..
    Sounds about right on hours to me.
    May 2016
    T-Town
    Timing chains - 6.7
    Oil pan - 6.6
    Thermostat - .9
    Thanks!!!!
    Nov 2007
    San Jose
    Sounds like a reasonable price to me, so long as they did all the work correctly. The new timing kit should server you well, the plastic hydraulic tensioners are a weak link in these cars.
    Lifespeed
    Nov 2012
    Sacramento
    Hours seem about right... I agree they could probably have "shaved off a few" hours if billed true hours vs. book hours.
    This said...
    It's fixed!
    It's done!
    Have some fun!
    Blog Entries
    2
    What is your time worth?
    I quit doing most repairs when my time became worth more than what I was paying to have it repaired.
    Timing chains - 6.7
    Oil pan - 6.6
    Thermostat - .9
    It can be done without dropping the pan, but it is a little fiddly.
    Trilogy # 192 / T.S. 0012
    Aug 2012
    Kansas City
    Hours are fair. You gotta pay if you are unable to do it yourself. Sorry bubs they are spot on.
    Neil
    2003 Mercury Marauder - SB/LF
    Maybe true, but won’t affect book time charged. Just a little more for the technicians pocket.
    ^^^^very true^^^^
  1. LCM Repairs
    By fastblackmerc in forum Marauder Innovations
    Last Post: 06-24-2022, 07:45 AM
  2. Last Minute Repairs
    By Curless in forum Marauderville 11 Updates
    Last Post: 09-23-2013, 11:38 AM
  3. LCM Repairs by Musclemerc
    By musclemerc in forum Musclemerc Products
    Last Post: 05-06-2011, 06:49 PM
  4. Dealer Repairs, . .
    By MM2004 in forum Shop Talk
    Last Post: 12-20-2004, 10:36 AM
  5. More Fun With Repairs
    By cyclone03 in forum Community Discussion
    Last Post: 06-21-2003, 10:35 PM
