I've had the Metco arms in for a little while now, and ever since installing them the car feels very tight in the corners. The problem I currently have since installing them is the back end wants to break loose more often or atleast thats how it feels. With the stock arms I could hug corners and the weight would transfer to the opposing side causing a little more body roll but atleast the tires would stick. Now I can almost forget what body roll feels like, but the weight doesn't seem to transfer as well, and the rear tires break loose more often. I'm not saying that it happens on 15 or 20 MPH turns, I am indeed pushing the limits, but I don't recall the back end coming out this much. One nice thing is when it does break loose, the rear end is so solid I can control it much easier than I could with the OEM control arms. I got the feeling with the OEM arms that they would flex, or the pressure applied into the rubber bushing would cause some shifting that would make the rear end bounce around.
Is there a term for this? and would the solution be wider rims & tires?
