Page 1 of 4 1234 LastLast
Results 1 to 15 of 50
Thread: So this happened.
    Aug 2010
    Gadsden, Al
    So this happened.
    During a WOT run on the interstate, it seems the car over rev’d and I drove on home. Everything seemed fine until I pulled in the driveway. The car seemed to have a miss. No overheating, no smoking, oil pressure still good. I pulled the passenger side plugs the next morning and found #3 as shown in the picture. I regapped the plug and put it I back in. Still has a slight miss at idle but it revs smooth. I have yet to pull the driver side plugs. Opinions please. The wetness on the plug is wd40 I sprayed in there before removing the plug.
    The Dirty South
    Wow.... I hope that's not piston contact...
    What else would it be?
    Aug 2010
    Gadsden, Al
    That’s all I can come up with
    The Dirty South
    Nothing else.... Just hoping this guy isn't in for a rebuild.
    Oct 2010
    Sorry to see this , but I think a rebuild is in your future.
    ITS ALIVE !!!!!!!!
    STAY TUNED!!!!!!!!!!
    Jun 2005
    long island ny
    how many miles on the motor?
    Aug 2010
    Gadsden, Al
    Quote Originally Posted by johnnyrauder View Post
    67k miles
    Aug 2010
    Gadsden, Al
    So this happened.
    Quote Originally Posted by JBeezy View Post
    67k miles
    Got a built cobra motor that’s built for boost, but...
    Engine from a ‘99 Cobra. Teskid block, DSS pistons and h beam rods.
    Oct 2010
    PA
    One of my DSS pistons, I used on my last build, came apart on me.
    SEMPER FI From York, Pa
    Aug 2012
    Kansas City
    Bet you broke a ring land. See my signature.
    Neil
    2003 Mercury Marauder - SB/LF
    Nov 2009
    NH
    Get a borescope and look at the top of your piston in that hole and look for any bits of metal also.
    Aug 2003
    Battle Creek, Michigan
    Quote Originally Posted by justgod View Post
    +1 on that
    First retailed 2003 Marauder
    Bought 6 June 2002
    #168
    A piece of piston came off. Continue beating on it. It detonated and you did not hear it
    Hopefully that piece of piston isn't still rattling around in the cylinder....
  1. What ever happened to....
    By SID210SA in forum The Lounge
    Last Post: 02-08-2007, 12:55 PM
  2. Has this happened to anybody else?
    By Mrsteamrope in forum Shop Talk
    Last Post: 02-11-2005, 12:24 PM
  3. What Happened????
    By wchain in forum Shop Talk
    Last Post: 01-13-2005, 09:53 AM
  4. It Happened...next?
    By merc406 in forum The Classic Lounge
    Last Post: 11-01-2004, 09:49 AM
  5. What Happened to Everyone?
    By Cobra25 in forum Sunshine State Marauders
    Last Post: 10-05-2004, 06:58 PM
