MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 01-30-2011, 08:22 PM
SGT_MERC's Avatar
SGT_MERC SGT_MERC is offline
Senior Member
Trader: (2)
2V intake, fuel rails, headers, upper intake plenum and throttle body
Just started pricing an intake replacement. Doing the Edelbrock Victor JR EFI intake with the Professional Products fuel rail kit this spring, along with headers. Trying to decide which way to go with the upper intake plenum and throttle body. Just did research and found out the 80mm 5.4l throttle body will work for a throttle body swap. Just need to find an upper plenum with an 80mm or larger bore, to go that route. Dragon Performance makes an oval upper intake plenum for the square flanged lower intakes. Does anyone know if the dual 62mm and 65mm throttle bodies are compatible with the tps and elec. motor plug ins. Voltage shouldn't be a problem, that can be adjusted to pre swap readings. If I'm not correct with my research, on the throttle bodies, please let me know. Thank You.
__________________
SEMPER FI From York, Pa
  #2
Old 01-31-2011, 08:40 AM
musclemerc's Avatar
Senior Member
Trader: (27)
Why not just do a PI swap?
  #3
Old 01-31-2011, 09:23 AM
SGT_MERC's Avatar
Senior Member
Trader: (2)
The 05 GM already has PI heads and intake. The Victor Jr intake, #28385, is made for the PI heads for the 04 mustang gt. That year engine set up is what I have always had to use when doing work to my car, but the 05 GM uses DBW throttle control. Everything below the throttle body is 04 Mustang.
__________________
  #4
Old 01-31-2011, 10:48 AM
scruff's Avatar
scruff scruff is offline
Senior Member
Trader: (0)
Quote:
what year is the 80mm 5.4L throttle body compatabile with the 05 and up crownvic what would i look for?
__________________
2006 P71 Vortech V3 Air -Air 10lb boost 373 gears
Dyno Tuned By Joe Dasilvia Raceing ,magnaflow mufflers best ET to date 13.63 , 103mph St thomas raceway June 2010
  #5
Old 01-31-2011, 11:07 AM
babbage's Avatar
babbage babbage is offline
Super Touring
Trader: (11)
There is some good info on these mods on crownvic.net
__________________
03 300A - Number 1727 - 13.8@99 N/A - Mods list - Garage
  #6
Old 01-31-2011, 11:13 AM
scruff's Avatar
Senior Member
Trader: (0)
oh no not that site lol
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
For Sale MM Upper & LWR Intake w/ TB,Fuel rails BODYMAN Marauder-specific Parts for Sale 2 12-31-2010 04:13 PM
Wanted To Buy Upper intake and throttle body tjl006 Marauder Parts/Misc. Wanted 5 08-30-2010 07:56 AM
Stock Upper intake plenum/valve body kit Mest30 Marauder-specific Parts for Sale 3 07-08-2008 05:35 AM
Intake Plenum crud... Big House Community Discussion 14 12-17-2006 10:08 PM
Throttle body intake spacers lsb532004 Community Discussion 2 09-03-2006 10:27 AM
Powered by: vBulletin
