Results 1 to 15 of 22
Thread: Time To Rebuild My Transmission
    Dec 2003
    New York, USA
    Cool Time To Rebuild My Transmission
    After doing a little research and asking a few people for recommendations,
    I've chosen Fred Brown Performance Transmissions in Bay Shore, NY.
    http://www.fbperformance.com
    Since my Dealer had to go to Bay Shore to get my Marauder,
    I figured I'd have to bring her back home to get any major work done she needed.
    They are going to do a full PRO STREET rebuild of my core, add a 300M Input Shaft,
    and rebuild my Torque Converter with new parts/stronger parts where needed.
    I asked about my differential, and they suggested getting rid of the pos factory one and getting something stronger.
    I've always wanted a Torsen and they agreed it would be a very good choice.
    They are getting prices on the Torsen now, and will reuse my gears
    as long as they are in good shape.
    Since I've been changing the oil every 30k miles, they should be in good condition.
    My Marauder has seen mostly highway miles and only lightly loaded.
    If everything works out well, I will be bringing her to Fred on Monday
    and back home before the end of the week.
    Pete...
    DOB 10/31/2003
    DOP 1/2/2004
    DOB 12/11/2018
    DOP 6/19/2019
    Jul 2010
    Guntersville Al.
    I notest your DOB was 10/31/03 the same as mine, and mine is #798. Halloween!
    It was an honor to have
    my ASS kicked by you!
    Rest In Peace!
    Paul T. Casey
    While you're at it might as well do the tailshaft lube mod kit and j-mod.
    http://www.dirtydogperformance.com/t...t/prod_57.html
    300B
    Exhaust by Greg
    2015 Ford Focus SE Sport FWD
    2010 Ford Fusion Sport FWD
    Dec 2003
    New York, USA
    I don't need either.
    The newer tailshafts come with a larger bearing surface.
    With this tranny build the J-Mod won't be necessary.
    Another change, I'm going with the Eaton Limited Slip instead of the Torsen.
    While the Torsen is geared, the Eaton is just as strong and can be serviced easily.
    The Torsen would have to be removed if it had any problems.
    Pete...
    DOB 10/31/2003
    DOP 1/2/2004
    DOB 12/11/2018
    DOP 6/19/2019
    Quote Originally Posted by MENINBLK View Post
    The larger bearing surface doesn't help or increase "splash" lubrication which is the only way fluid gets back into the tailshaft, that's where the TS lube mod helps. Just saying.
    300B
    Exhaust by Greg
    Nov 2010
    schenectady
    Good choice.I have been using a FB-4STB trans w/manual valve body in Purple Panther for 5 years with no problems.
    Jul 2008
    Near Nashville, TN
    You'd probably be better off with an off the shelf aftermarket torque converter with the stall rating of your choice. What exactly is the shop going to replace inside the converter?
    Also you mentioned an aftermarket Torsen diff. Check the price on that, and compare it to the 31 spline Terminator OEM carbon clutch diffs that Tousley Ford is selling for $158.00 + shipping. That is a STEAL. Depending on what you are spending on that Torsen diff, you could possibly have the awesome 31 spline Cobra diff and a nice set of aftermarket 31 spline axles for the price of said Torsen diff.
    All just food for thought
    Black 03 Marauder
    93 Reef Blue Mustang LX Coupe - LQ9/T56 Swap underway
    Dec 2003
    New York, USA
    Quote Originally Posted by ReefBlueCoupe View Post
    Already looked into this.
    Rebuilding my TC is $395. Blue Oval Chips has an upgraded TC for $455.
    They are doing the same thing that BOC does to theirs
    for $60 less and it will still be my original core.
    I am going to call Tousley Ford about the Diff package.
    What do you suggest for 31-spline axles ???
    Thanks !!!
    Pete...
    DOB 10/31/2003
    DOP 1/2/2004
    DOB 12/11/2018
    DOP 6/19/2019
    Jul 2008
    Near Nashville, TN
    Thanks !!!
    Hey, my bad about saying they were $158. Further down in the thread on SVT Performance, he mentions that they are $174.65. Still a killer deal.
    Thread: http://www.svtperformance.com/forums...-158-77-a.html
    As far as axles, opinions will vary depending on who you ask but I've run Strange and Moser, and had zero problems with either. I would be fine with either and it would come down to price for me.
    The only real choices you'd have to decide on are screw-in vs press-in (I prefer screw in due to ease of changing if you should crossthread or break one.. breaking one is unlikely unless you're making big power and drag racing a bunch) - the other choice is stock length studs vs 3". 3" are nice if you are drag racing a bunch because they allow you to meet the NHRA rule about the threads sticking out past the nut a certain distance when running slicks, but are not required for you to do. 3" studs also stick way out and look odd with a factory wheel because of that.. and you have to run an open-ended lugnut. If it were me, I'd choose stock length.
    Hope this helps.
    Good deal on the TC stuff you mentioned. Sounds like a good call.
    Black 03 Marauder
    Dec 2003
    New York, USA
    Any sources for the axles ?? Sources with DISCOUNTS ???
    Pete...
    DOB 10/31/2003
    DOP 1/2/2004
    DOB 12/11/2018
    DOP 6/19/2019
    Jul 2008
    Near Nashville, TN
    I do not know.. possibly one of the vendors here?
    Black 03 Marauder
    Dec 2003
    New York, USA
    I'm checking with Ray (TheDealer) on Ford 31-spline now.
    (6W1Z-4234-A)
    I'll entertain any other quotes until I make my decision.
    With the COBRA diff, I might just go with the Ford Axles.
    Pete...
    DOB 10/31/2003
    DOP 1/2/2004
    DOB 12/11/2018
    DOP 6/19/2019
    Dec 2003
    New York, USA
    Purchased everything I needed from Tousen Ford.
    Picking up Marauder this evening !!!
    Pete...
    DOB 10/31/2003
    DOP 1/2/2004
    DOB 12/11/2018
    DOP 6/19/2019
    Jul 2008
    Near Nashville, TN
    I hope it's awesome!
    Black 03 Marauder
    Dec 2003
    New York, USA
    BOY, I never knew how sloppy the drive train was from FORD.
    The tranny is excellent now.
    Works even better together with Lidio's tune.
    Shifts quick and nice when I'm easy on it.
    Shifts Quick and FIRM when I jump on it.
    The rear axle is smooth and quiet now.
    It used to clunk when I went from drive to coasting and back.
    Fred Brown did a great job for me !!
    I recommend anyone in the NY/NJ/CT area to go to Fred Brown
    for all your transmission and rear axle work !!!
    All he does is performance transmission and rear axle.
    Fred has been doing this for more than 20 years !
    Pete...
    DOB 10/31/2003
    DOP 1/2/2004
    DOB 12/11/2018
    DOP 6/19/2019
  1. rebuild
    By STRAN in forum Transmissions
    Last Post: 11-16-2011, 05:53 PM
  2. To rebuild or not?
    By 03sport007 in forum Power Adders
    Last Post: 09-22-2011, 08:08 PM
  3. My rebuild
    By Juice in forum Transmissions
    Last Post: 01-18-2011, 05:44 PM
  4. Transmission Rebuild/Replacement Question....
    By AnthonyV8 in forum Shop Talk
    Last Post: 01-08-2007, 09:10 AM
  5. Time for a rebuild?
    Last Post: 08-11-2006, 09:58 PM
