Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: crossover tube plug is rusted!
    Jun 2017
    Oxford, PA
    Hello
    --replaced the oil adapter gasket
    trying to burp the cooling system...cannot get the crossover tube plug loose.
    ---used vise grips
    --sprayed liquid wrench
    --spray Kroil
    I am soaking the plug overnight in liquid wrench...I cut a funnel and jammed it over the crossover plug boss, filled it with liquid wrench so the whole thing would be submerged all night.
    Any other tips/tricks? Eventually I'll do a cooling mod but was hoping to put that off while I fixed other things.
    Thanks for any comments....
    Sep 2008
    B'lo, NY
    Blow torch. A little heat goes a long way.
    To do list:
    The Dirty South
    WOW!!! Look @ the COT
    Don't throw heat at it. Look for a replacement
    Jun 2017
    Oxford, PA
    ..and look at the aluminum parts, this car was parked near the ocean in NJ, looks like a shipwreck. LOL. I'm think either ON3 or ... does Zack sell/recommend a cooling mod?
    (this car is fighting me, but I think i'm winning. Got the interior door panels back in today, replaced
    --door module
    --drivers door regulator, motor, switches and door panel. Basically everything. I had a good Marauder door shell and smashed door. Thought I could reuse at least the regulator, but NO! apparently a little too much side/side play in the good doors track, window was binding, so I went back in a swapped everything back out.
    --r/r door window motor and regulator --- suspected it was bad, but was probably the drivers door master switch, I didn't pick up on the fact that the switches are wired in series. So I got to redo that whole door too.)
    other observation --- I drained the radiator to do this repair, got about 1.1 gallons out. I slowly poured one gallon of Zerex in to refill. How much burping do I still need to do? Front of car was on ramps....thanks.
    The Dirty South
    On3 is the cheapest option and as far as a cooling mod here's a good option
    https://www.mercurymarauder.net/foru...d.php?t=107064
    Sep 2004
    Roanoke, VA
    I've used a hacksaw blade to cut a groove across the top of the plug, then use a screwdriver and hammer to tap it loose turing left.
    04 MM Silver Birch/Light Flint, HS, TO, 6CD, #597 of 3214 (sold 5/2014)
    06 MGM LS Ultimate w/HPP, Black/Dark Charcoal
    04 MGM LS Ultimate
    69 Marquis convertible, 429
    95 F250HD 7.3 4x4
    48 Ford F4
    Weld a nut to the top of it, then use a bigger tool.
    Try and pop it / shock it to loosen it vs continuous pressure
    Oct 2014
    Charlotte, NC
    Lightbulb
    Then DON't reuse it. Get a custom COT cap...mine has the Mercury God's Head.
    Current Garage:
    2005 Mustang GT Premium
    2015 Triumph Trophy SE
    William W. Purkey
    Blog Entries
    2
    Be aware of any residual flammables when using a flame.
    Oct 2008
    Massachusetts
    Go On3, that COT is on borrowed time.
    Unless you are over insured.
    Trilogy # 192 / T.S. 0012
    Apr 2010
    South Florida
    Tap tap with a hammer, turn it with channel locks.
    Jun 2017
    Oxford, PA
    Thanks guys for all the guidance, this plug is on there been tapping for an hour, tried a punch on the edge....I'm moving on to ON3 -crossover delete! sorry for all these Questions:
    1.Street driven car, do I want the two temp sensors? (I assume I do)
    2. Do I want the AN/line fitting install kit ? why would people not order an install kit?
    3.two rear head fittings or one? --(can this be installed without yanking the engine or heads?)
    https://www.on3performance.com/shop/...delete-2-port/
    final question, does this also replace the metal tubing that runs along the pass side cylinder head? That is pretty severely rusted on my car as well.
    Many thanks for your comments!
    Oct 2014
    Charlotte, NC
    Arrow
    Thinking I would pay someone to fabricate a stainless COT from scratch. Yeah, I know it won't be cheap.....
    Current Garage:
    William W. Purkey
    Oct 2008
    Massachusetts
    1. Yes, two sensor
    2. That’s up to you, I did and I was happy with the lines and fittings it came with.
    3. This is completely up to you as the kit is designed to allow you unlimited flexibility in how you design your cooling system. I used two, D/S routed to the thermostat housing port, P/S to the Heater core. I deleted the PCV cooler line and plugged it with a silicone cap. If you route yours the same way as me it will delete the metal line you are referencing. You can do it all in the car, intake manifold removal will be needed to install the fittings.
    If you have any other questions or want some pics send me a message.
  1. Crossover tube plug problem
    By Chevyguy in forum Shop Talk
    Last Post: 10-11-2016, 08:52 PM
  2. Crossover tube plug troubles
    By jimlam56 in forum Shop Talk
    Last Post: 11-30-2013, 03:36 PM
  3. For Sale Brand New OEM Crossover tube/ FBM plug
    By loud2004marquis in forum Marauder-specific Parts for Sale
    Last Post: 08-14-2013, 11:34 AM
  4. rusted crossover tube
    By Jeffonebuck in forum Community Discussion
    Last Post: 04-24-2013, 04:13 PM
  5. Crossover tube plug locked up!
    By Svashtar in forum Shop Talk
    Last Post: 07-12-2008, 11:43 AM
