Results 1 to 4 of 4
Thread: Rotating Clicking sound from rear axle area
    Nov 2003
    Monroe, NC.
    Cool Rotating Clicking sound from rear axle area
    My question is I had a right rear axle seal leaking so the dealer preformed a TSB and replaced both right and left axle's, and bearing and seals. Now my car has a rotating clicking sound that I only noticed after I pick up the car when I was turing right. I took the car back and left it for another week and the tech said he adjusted the parking brake shoe and the concern is gone. Well it is not and before I take the car apart my self does any one have any Idea's. Thank you for your time. 03mmcorpus
    Thank you for the information but I have found out the sound is comming from the parking brake shoe area and the inside of the rotor has a rust ring that the shoe is hitting. I think I will have the dealer install two new rear rotors and adjust the rear parking brakes. I will let you no how it turns out.
    Russ, Monroe NC.
    Oct 2003
    Beaufort, SC
    Sounds like they forgot the "Friction Modifier" in the gear oil??
    Posi-Trac clutches will click and pop going around turns without it!!
    Try a 4 ounce bottle first.....I'll bet they forgot it as most big Ford cars and trucks don't have Posi's??
    Marauderjack
    ^^^what Marauderjack said^^^
    Long Island, NY
    Marauderjack
    I also concur. Sounds like the differential clutches.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
  1. Rear axle defect
    By valleyman in forum Community Discussion
    Last Post: 07-24-2004, 12:19 PM
  2. MM rear axle type? and request for MM engine picture..
    By Brett in forum Community Discussion
    Last Post: 12-04-2002, 06:01 AM
  3. Rear axle spline count
    By cyclone03 in forum Community Discussion
    Last Post: 09-19-2002, 01:54 PM
