Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: Air compressor bad!?!?!
    Apr 2011
    Statesville, NC
    Left my car sitting for 2 days with about 300 lbs of stuff in it (moved to nc). Come back to get the car and about 5 minutes down the road notice my air suspension light on. Had my wife pull next to me and the car seemed at a normal level so I continued driving approx 3 hours.get to the house, unload everything and car goes back to normal level. Get back in the car to day and the same thing happens, this time accompanied with harsh ride since I wasn't on the freeway. Noticed car was bottomed out in the rear so I drove it home and started researching. Found the Lincoln troubleshooting page for air ride and found even with pins 30 and 87 jumpered on the air suspension relay under the hood (#303)compressor would not cut on so I'm looking for replacements, am I safe in assuming it's the compressor and not the module??
    Apr 2011
    Statesville, NC
    Also I'm getting 12 volts on pins 30 and 87
    Feb 2012
    harrison twp,mi
    Suncor about 200 bones if I recall
    Those were the days.........
    DANG THEY'RE CUTE!!!!!!
    Smile and Nod
    I love THIS bar
    Could be a bad pump or a bad connection elsewhere.
    Where in N.C. did you move to?
    Apr 2011
    Statesville, NC
    I'm in kannapolis, 28083
    Quote Originally Posted by jwibbity View Post
    Close to marauderman and 03mmmonroe. Keep an eye on the Carolina Marauders forum. Welcome to N.C.!!!
    Apr 2011
    Statesville, NC
    Well got another compressor on the way, let's see if that's the issue....
    Apr 2011
    Statesville, NC
    Got another compressor in today, no more air compressor pumping up the bags!!!!
    So still not working???
    Apr 2011
    Statesville, NC
    Well put in different compressor, not new but a different one and same results, compressor wont turn on, thinking maybe the module? Its sounds the same as if the compressor starts to turn on but doesnt kick the pump on same as last......
    Apr 2011
    Statesville, NC
    http://www.mercurymarauder.net/forum...ad.php?t=80838
    Heres a link to an old thread about popping a related fuse, #114 under the hood, that just disappeared and hasnt happened since, maybe whatever was shorting has finally broken??
    Apr 2011
    Statesville, NC
    I see a rear coil conversion in my future
    Nov 2007
    San Jose
    Giving up already? The air suspension is one of the premium features of the car. Most on this board would recommend fixing it.
    Your car though.
    Lifespeed
    I'll reply to your PM tonite.
    Oct 2003
    Beaufort, SC
    Check the relay under the hood if you haven't already.....they tend to self destruct over time!!
    My AC compressor one and the air suspension one have been replaced for the same "no run" or intermittent problems!!
    Good Luck in "Earnhardtville"!!
  1. Air compressor
    By Bob Emess in forum Steering, Suspension & Brakes
    Last Post: 04-28-2013, 11:33 AM
  2. Wanted To Buy Air Compressor
    By HEAVY HITTER in forum Marauder Parts/Misc. Wanted
    Last Post: 03-28-2012, 12:35 PM
  3. Air compressor
    By dakslim in forum The Lounge
    Last Post: 05-17-2010, 12:20 PM
  4. air compressor. how to detach the air line
    By ImpalaSlayer in forum Shop Talk
    Last Post: 01-07-2010, 04:42 PM
  5. Air Compressor
    By MarauderBoy in forum Steering, Suspension & Brakes
    Last Post: 09-03-2009, 02:14 PM
