MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Transmissions
Transmissions This forum is to exchange information about the 4R70W & 4R75W transmissions.
Reply
Thread Tools Display Modes
  #1
Old 05-25-2018, 05:19 AM
01MercGMLS's Avatar
01MercGMLS 01MercGMLS is offline
Member
Trader: (0)
Shudder
I'm having an issue with my 2001 Grand Marquis LS. While I'm on the highway from 50 mph on up if I come to a slight uphill where you have to give just a little more throttle to maintain speed I get a wicked shudder. If I hammer on it the shudder goes away. If I let off the shudder foes away. It also seems to happen in top gear as the torque converter locks up.
Does anyone have any idea what's causing this and how I can fix it?
The car was a 1 owner car. A school teacher that drove it from Jerseyville, IL to St. Louis, MO. It has 157,000 miles on it and is in great shape. I can't fathom an older school teacher running the car hard so I don't think it's transmission damage. Thinking maybe wear or needs a fluid change.
I'm open to suggestions. Any help would be appreciated.
Thanks in advance,
Aaron
  #2
Old 05-25-2018, 05:28 AM
Gerry24's Avatar
Gerry24 Gerry24 is offline
Senior Member
Trader: (1)
I would suggest changing coils, plugs and checking the mass air flow sensor. And let the trouble shooting begin
__________________
Righteous Indignation
03 300A
4055 of 7838
4054 of 7093 in Black.
Born 8/23/02
Adopted in 1/15.
  #3
Old 05-25-2018, 05:30 AM
TORINO's Avatar
TORINO TORINO is offline
NEED FOR SPEED
Trader: (0)
Could also be an engine misfire, plug or coil. If it is the trans has it been serviced ?
__________________
73TORINO SPORT 110K M. BOUGHT NEW
04 DTR 42K M.
03 BLK 8K M.
07 GT500 9K M.
98 MARK VIII 65K M. BOUGHT NEW
05 NAVIGATOR 95K M. SNOW DD
17 MUSTANG GT
18 GENESIS G80 5.0
  #4
Old 05-25-2018, 05:45 AM
01MercGMLS's Avatar
Member
Trader: (0)
I've only had the car for 4 months. The CarFax report is immaculate. The original owner was all over the service intervals so I'm almost sure it's been serviced. I'm just not sure how long ago. I'd have to go back and look. I wondered about a misfire but since I'm new to Ford and Mercury (Chrysler guy) I wasn't sure. Do these cars register a cylinder misfire? I haven't ever had a check engine light come on.
A tune up is in my plans but was waiting until next month. Had some unexpected expenses this month.
  #5
Old 05-25-2018, 05:54 AM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
MIsifre does not always register a check engine light, I believe it generally a repeat process where the same cylinder must misfire 'x" times over "x" time for it to turn on the CEL. Is the trans fluid correct level, clean and bright red? if it is dark, burnt smelling, past due for service. The factory tuning on these cars (cv, mgm, marauder) is based on gas mileage so the trans has poor shifting parameters by getting to OD asap then hunting for which gear to be in based on rpm etc..Torque converter shudder can happen. Often a fluid change helps, scan for codes even if one is not showing, check plugs, cops..especially if original. dirty MAF, vacuum leak.
__________________
  #6
Old 05-25-2018, 06:00 AM
01MercGMLS's Avatar
Member
Trader: (0)
One other thing I've noticed happening to mine and my buddy's car is the IAC howl. They're both the same year and roughly the same mileage. The research I've done says it's hard to get that to go away permanently. It does it while cruising on the highway, sitting at stoplights, and at startup. When it's howling the engine runs at a higher RPM. Could this be causing issues as well?
  #7
Old 05-25-2018, 06:11 AM
Weißbirke Plünderer
Trader: (11)
clean the iac or change it, they are not expensive..they get dirty with carbon
__________________
  #8
Old 05-25-2018, 06:23 AM
01MercGMLS's Avatar
Member
Trader: (0)
Quote:
Thank you for all your help. I love this car! I just need to get these couple bugs worked out and she'll be good to go.
  #9
Old 05-25-2018, 11:44 AM
Joe Walsh's Avatar
Joe Walsh Joe Walsh is offline
STILL N/A
Trader: (8)
Flush the transmission....
My Mom's 1996 GM had the same problem...turned out to be the OD function in the transmission. It had just under 90,000 miles IIRC.
We changed fluid/flushed the trans and the problem was gone....drove smooth as glass after that.
__________________
2017 Ford Fusion Sport DFI. Twin Turbo V6 6 speed Auto
1985 Mustang GT 5.0 Hatchback 4bbl 5 speed manual
1999 Ranger 3.sl0w DD/Beater
  #10
Old 05-25-2018, 01:12 PM
BLACKMARAUDER04's Avatar
BLACKMARAUDER04 BLACKMARAUDER04 is offline
Member
Trader: (0)
Turn your OD off and test that theory.
  #11
Old 05-25-2018, 02:37 PM
Marauderjack's Avatar
Marauderjack Marauderjack is offline
Senior Member
Trader: (13)
Torque Converter shudder.......add one 4 ounce bottle of FORD Friction Modifier......the smelly one for the rear end LSD.......if it goes away you are fine and can do a flush later......it's the same additive that comes in Mercon V fluid!!
This has worked for me from the Mid-90's in every CV I've had and I had 6 of 'em and ONE GREAT MARAUDER....used it in it too!!
__________________
Member #1368
2004 Silver Birch...300A
#948 of 3213/#8787 of 11052
FIT "ProCharger" #0010
Real AutoMeter Oil Pressure Gauge
Addco Anti-Sway Bars
ScanGauge II In Dash
Nitto 295's On Widened Rears
Mach I Air Dam
  #12
Old 05-26-2018, 06:42 AM
01MercGMLS's Avatar
Member
Trader: (0)
Thanks guys... I'll try a flush next week. Today I fixed the annoying intake howl.
  #13
Old 05-26-2018, 07:07 AM
01MercGMLS's Avatar
Member
Trader: (0)
With the OD off it still does it as the converter locks and unlocks.
  #14
Old 05-26-2018, 09:55 AM
01MercGMLS's Avatar
Member
Trader: (0)
I'm going to buy a 4 ounce bottle of friction modifier today and give that a shot. I'll flush the trans next month and add another 4 ounce bottle. I want to try to make this tranny last.
  #15
Old 05-26-2018, 12:52 PM
Senior Member
Trader: (13)
Go for it......it will not hurt a thing and hopefully fix your problem!!
WARNING......DO NOT SPILL ANY...IT STINKS FOR A LONG TIME!!
__________________
Member #1368
Mach I Air Dam
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Trans. Shudder Bob Mathis Transmissions 17 11-16-2015 09:34 AM
Transmission shudder.... dickmerc Transmissions 8 04-28-2015 02:28 PM
Transmission shudder Leadfoot281 Shop Talk 22 09-22-2005 11:41 AM
Brake shudder? MTAMERC9 Community Discussion 6 05-20-2005 03:50 PM
Shudder 01True BlueGT Shop Talk 1 11-27-2003 10:14 AM
Powered by: vBulletin
