I tried to send you a PM and when I sent it I got a message your inbox was full........how about PM me and let me know how to contact you.......got a question for ya??
Marauderlessjack
Marauderlessjack
CBT probably has him stuffed full.
I hate when your Inbox is stuffed full....
Guess it would be worse if your Outbox was stuffed full! ....
Awwwwwww what is it? In or outbox stuffed full? I wish you guys would speak in plain terms ...🤪
Trilogy # 192 / T.S. 0012
It's no accident his mailbox is full and will never be emptied.
WIN WIN!~ Zack
