Results 1 to 12 of 12
Thread: Powdercoated Marauder wheels
    Jun 2004
    Toronto, Ontario
    I was looking for some Marauder wheels for the track and Cruztaker suggested Blackburns Hubcap in Ohio. I picked up some full sized spares that had been sprayed black for a sweet deal.
    Before pic:
    I got them powdercoated by a place called Teff line in Burlington for $40 each.
    Here are the after pics:
    Ready for slicks.
    Wes
    Blue 300B Marauder
    Dec 2003
    New York, USA
    Why didn't you powdercoat the inside of the RIM ?
    It needs to be protected from the moisture in the air inside the tire,
    unless you plan on filling your tires with NITROGEN.
    Pete...
    DOB 10/31/2003
    DOP 1/2/2004
    DOB 12/11/2018
    DOP 6/19/2019
    Wesman, what did they charge you for that? They look very very nice!
    They do look nice, but they strike me as something that will scratch very easily...?
    2005Marauder Guest
    I like them.
    May 2004
    (The other West Coast) Wyoming Michigan
    "PC" WHEELS
    Me LIKEY the look also...I priced powdercoat @ 2 places in Grand Rapids MI...both abt. $40 ea....& BOTH said they ALWAYS do the WHOLE wheel inside AND out
    Quote Originally Posted by MENINBLK
    Quote Originally Posted by Rider90
    I've had many different engine and suspension pieces powdercoated and have found the coatings to be thick and tough.....resistent to dings, chips and scratches.
    Brake fluid does not touch the powdercoating either.
    Nice Looking Rims!
    Jun 2004
    Toronto, Ontario
    Quote Originally Posted by shakes_26
    It was $40 Canadian each. I really hope they don't easily scratch, but they are for racing only anyways, they are going to get beat up.
    Wes
    Blue 300B Marauder
    Long Island, NY
    They look great.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    Hiram, Georgia
    I like 'em!!
    Los Angeles - California
    I have had bumpers powdercoated and they never chipped. Powcercoat is very tough.
    2004 BLACK MERCURY MARAUDER
    SCT
    JLT Cold Air Induction
    PHP Intake Spacer
    Cobra Ported Manifolds
    Flowmaster 50's
    Magnaflow X-Pipe
    Stallion TC
    4:10's
    Steeda Underdrive Pulleys
    Rear sway bar
    1969 GREEN MACH I MUSTANG GT
    351 Windsor
    Shelby Cam
    Shelby Tri-Y headers
    Ported and polished heads
    10.5:1 Domed pistons/rods
    Balanced and blue-printed
    Offenhauser Intake
    NOS plummed under intake (8 fuel injectors, 8 NOS injectors)
    Art Carr TC
    Tranny shift kit
    Dual ignition with MSD
    3:90 Posi rear end
    Bought car when I was 16 and still have it
    Quote Originally Posted by wesman
    Disregard that suggestion.....
    Powdercoat properly applied and baked is hard as rock and won't scratch any more than the paint on your car or the polish on the rims.
    I assume they clearcoated over the powdercoat. Most places do.
    Overall you did good. Torrie told me you bought those ugly ass wheels, but wouldn't tell me what he charged you.... I hear it was a good deal.
    He can't keep a MMwheel on the shelf for long since I started redirecting all you folks to his shop. I think he has one maybe two right now.
    I like your results, and let me tell you, mine, being completely coated inside and out, clearcoated, and outer rim polished, ran $275 a wheel. You got a bargain man!
    2017 Niro
  1. 6 weeks with Marauder
    By 213Cobra in forum Community Discussion
    Last Post: 12-30-2016, 05:47 PM
  2. Replies: 38
    Last Post: 11-21-2006, 08:36 PM
  3. Getting some new wheels, need tires
    By Sully008 in forum Tires & Wheels
    Last Post: 10-14-2005, 07:18 AM
  4. Potential new Marauder owner? (many questions...)
    Last Post: 02-02-2005, 12:32 PM
  5. 2004 Marauder
    By RCSignals in forum Community Discussion
    Last Post: 07-11-2003, 05:20 AM
