I’ve been giving the beast some needed TLC and still have a few projects ahead of me. But, the head unit was returned yesterday so with any luck the Lemonade will be functional this weekend.
I know installing the head unit isn’t all that labor intensive but I’ve done a lot since the last time it was started a month ago:
Cleaned the oil off the engine from the head unit,
Cleaned & re-oiled air filter,
Changed the O2 sensors,
Installed the front shocks,
Installed new upper control arms,
Put in new spark plugs,
Changed back to the OEM coil covers,
Changed the oil,
Cleaned more oil off the engine from the head unit,
Had a port welded close in the COT,
Re-soldered the DR window control switch,
Cleaned the contacts for the mirror controls,
Cleaned the catch can reservoir,
Cleaned even more oil off the engine from the head unit.
Will be installing a new belt when installing the head unit.
