If you are going to spend big coin ($800) on a custom driveshaft buy a Carbon Fiber Driveshaft from PST.
Carbon Fiber is extremely stiff and vey light...but NOT cheap.
They built one for me and it weighs 13 lbs....it is a thing of beauty.
Too bad it's tucked up under the car....
linky: http://www.pstds.com/
