MercuryMarauder.net Forums
Go Back   MercuryMarauder.net Forums > The Garage > Steering, Suspension & Brakes
Steering, Suspension & Brakes Post your discussions about steering, suspension, shocks, control arms and brakes here!
Reply
Thread Tools Display Modes
  #1
Old 11-30-2012, 06:17 PM
whitey whitey is offline
Closed
Trader: (3)
i need a coilover spring!
so i just had new front tires put on today, which i put off until the steel belts were showing because I AM BROKE! and the mechanic pointed out that my driver side coilover spring is broken, near the bottom, and im slightly concened on if i should be looking to get new coilovers or can i wait until im back working? also, my rear brake pads are near completely gone, so im going to need rear pads too. i thought that the brake pads had something that made them start to squeal when they got low? i never heard anything. i do some searching on here for brake pads, i know its been discussed a lot. thanks guys.
  #2
Old 11-30-2012, 08:23 PM
fastblackmerc's Avatar
Trader: (75)
Most brake pads have a metal tab that contacts the rotor when the stopping material has worn to a certain point.
For the front spring....... the longer you let it go the more damage it could cause.
__________________
  #3
Old 11-30-2012, 09:42 PM
ctrlraven's Avatar
ctrlraven ctrlraven is offline
BiRDMAN
Trader: (28)
The fronts are not coilovers, that's an adjustable system strut/spring system. Our is a MacPherson strut setup, coil spring and strut combined in one unit. Check rockauto.com to see how much a new front coil spring would be. With brake pads, those wear squeal metal tabs sometimes don't come on discount brand brake pads.
__________________
300B
Exhaust by Greg
2015 Ford Focus SE Sport FWD
2013 Lincoln MKS EcoBoost AWD
2010 Ford Fusion Sport FWD
2006 Ford F-350 SD Amarillo
1989 Ford Mustang 5.0 LXsport
  #4
Old 11-30-2012, 09:51 PM
EMAS EMAS is offline
Senior Member
Trader: (0)
Quote:
Yes they are coilovers. Coilovers do not have to be adjustable though many of the aftermarket ones are.
A strut locates the suspension as well as carries the weight of the vehicle. Within strut style suspensions the MacPherson version is a very specific set up that Ford hasn't used since the Tempo went out of production.
  #5
Old 11-30-2012, 10:14 PM
ctrlraven's Avatar
BiRDMAN
Trader: (28)
http://en.wikipedia.org/wiki/Coilover
Quote:
A coilover is not to be confused with the shock absorber and spring setup (strut); coilovers are totally independent and do not require extra parts e.g. bumpstops, ball Joints, spring cushions etc. Many people state that they are the same but this is a busted myth, hence the reason that high performance cars use independent coilovers to increase road grip, handling and comfort. On a lower budget, people will install a 'lowering kit' consisting of a spring that is of different measurement in length (mm) and fit aftermarket shock absorbers to increase comfort and handling on tighter corners where body roll may hinder performance. Coilovers come adjustable or a fixed length and normally bolt straight to a car instead of using tools (spring compressors) to fit a shock absorber and a spring to. While they are generally more expensive (up to 90% more), they still offer the greatest amount of comfort and handling compared to the earlier, strut-mounted type.
The front suspension on the Panther platform is a Macpherson strut.
__________________
300B
Exhaust by Greg
  #6
Old 11-30-2012, 10:59 PM
Senior Member
Trader: (0)
Did you even read the mostly incorrect wiki entry? The a couple of the factual points are "It consists of a shock absorber with a coil spring encircling it." and "Coilovers should not be confused with struts or independently mounted shock absorbers."
Have you even looked under your car? If you did you'll see that it looks nothing like the picture you included which is a strut type suspension but not a MacPherson strut suspension. Another factual point from wiki "MacPherson strut suspension system, which is distinguished from other arrangements by employing a particular design of anti-roll bar as a longitudinal constraint." See the patent http://www.google.com/patents?id=Qup...949%2F&f=false and you'll see since it uses a lower radius rod to provide fore aft location of the lower control arm it is not a MacPherson strut suspension since in a MacPherson strut suspension it is the anti-roll bar that does that function.
Panther front suspension note the upper control arms that are the upper locating device.
But a strut suspension does not need the coil spring mounted to the dampener, see the Fox front suspension which is a strut type suspension since the dampener does locate the suspension but the coil spring is mounted on the lower control arm as pictured below.
There are even strut style suspensions that use torsion bars as the spring component such as the Porsche 911 pictured below.
  #7
Old 11-30-2012, 11:02 PM
tbone tbone is offline
Supporting Member
Trader: (3)
Rear pads are cheap and easy to install. Wagner ceramics on ebay are only $30! Rotors are cheap these days and turning them is even cheaper! You can do it! Get a service manual if in doubt.
  #8
Old 11-30-2012, 11:27 PM
ctrlraven's Avatar
BiRDMAN
Trader: (28)
Yes I can read thank you and I was being general as which the picture is GENERAL as well since there is alternatives and variants to suspension types due to unibody vs full frame, FF/FWD vs MR/RWD vs RR/RWD. I never said the picture that was posted was of the Panther setup, again being general. I've looked plenty under my car as I turn my own wrench as much as possible when I do not need a lift.
whitey, rockauto.com has front Moog springs (sold in pairs only) for like $60, Advance wants $110 for the same item.
__________________
300B
Exhaust by Greg
  #9
Old 11-30-2012, 11:38 PM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
Broken springs are way more common than most know. It will be fine..
__________________
  #10
Old 12-01-2012, 12:05 AM
Senior Member
Trader: (0)
I never accused you of not being able to read, just asked if you actually read those links you provided.
Yes, the picture you posted is of a GENERAL strut style suspension not a MacPherson strut suspension even though it is on the page for "MacPherson strut suspension" which is a very specific type of strut suspension. Which just proves you can't trust Wiki to be fully factual.
For the record the Panther uses a SLA (Short and Long Arm) suspension with Coil Over shocks per the Ford brochure.
Sorry if I'm coming across as a troll, I just take offense to besmirching the Panther's good name by saying it uses a MacPherson strut suspension, whose primary design goal was to provide the absolute lowest possible cost for the proposed Chevy Cadet in 1947
  #11
Old 12-01-2012, 05:25 AM
Closed
Trader: (3)
Thanks everybody.....emas and Ctrlraven, my head just exploded, now kiss and make up...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
coilover,lowering springs bigmerc281 Steering, Suspension & Brakes 9 11-06-2012 01:08 PM
S spring k4029ppy Shop Talk 2 05-08-2011 06:17 AM
Is it spring yet? jdando Photography Forum 10 02-24-2011 08:35 PM
Spring in MN jdando Photography Forum 1 05-09-2010 04:16 PM
coilover change out burt ragio Community Discussion 1 04-11-2008 10:57 AM
Powered by: vBulletin
