MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 11-13-2017, 10:11 PM
Blown3.8's Avatar
Blown3.8 Blown3.8 is offline
Mr. Hankey
Trader: (2)
JFlave's Upgrades
Well the end of last season we found that John's IC wasn't up to cooling 20 something pounds of boost. So we picked up a Treadstone 6" thick Intercooler and built some aluminum IC tubes instead of the steel ones.
With the old IC it would pick up 70* iat in a 10.5 second quarter mile pass and it would pull a bunch of timing getting to 180*. With the new IC we are seeing a 30* increase and also seeing 3 more pounds of boost. The new IC weighs about 20lbs more than the old IC, but going to the aluminum tubes we only gained about 7 lbs total. Lost 4lbs per tube. Got the IC tucked up just behind the bumper.
20171025_183517 by Chris Vining, on Flickr
20171105_171042 by Chris Vining, on Flickr
20171101_004403 by Chris Vining, on Flickr
ic front1 by Chris Vining, on Flickr
ic front by Chris Vining, on Flickr
20171105_144902 by Chris Vining, on Flickr
20171105_171125 by Chris Vining, on Flickr
Had to use 2 vortech blow of valves before to keep the boost from backing up when the throttle was cut. Now we went with a single Tial valve in purple of coarse. Not that you can see it.
20171025_183939 by Chris Vining, on Flickr
20171103_224103 by Chris Vining, on Flickr
20171105_155124 by Chris Vining, on Flickr
__________________
~Chris
  #2
Old 11-13-2017, 10:23 PM
Blown3.8's Avatar
Mr. Hankey
Trader: (2)
Neither were the radials holding the track under the more instant boost the Circle D converter brought on. So John picked up a set of Race Star wheels in 18x10.5 rears and 18x5 fronts. M&H tires now makes a 18x10.5 slick and 18" bias front runners!
John had the front wheel pad machined down the max amount race star recommends(I forget the spec) so the front wheels wouldn't poke out from the fenders.
And the rears fit PERFECT! No spacers, nothing. May need longer ARP studs though. As the mag style nuts were right at the end of the ARP studs. The pads on the wheels are super thick.
Race Star 1 by Chris Vining, on Flickr
Race Star 2 by Chris Vining, on Flickr
Race Star 3 by Chris Vining, on Flickr
__________________
~Chris
  #3
Old 11-13-2017, 10:25 PM
TAKEDOWN's Avatar
TAKEDOWN TAKEDOWN is offline
Mount UP and Take em' DOWN!
Trader: (23)
Simply Hardcore!
__________________
"Damned if I do, damned if I don't!"
Member #8831
MERIDEATH aka "Purrrty Mean" was born on June 20, 2002.
Production #1685 of 7,838 and is #1685 of 7093 Black Beasts.
Delivered July 27th 2002, she revealed herself.
Unable to be tamed by her 1st owner, she was left to roam about & raid in search of plunder.
Through the pillage she became mine on January 23, 2008 and since then...
"She's tryin' to make a Devil out of me!"
-"TaKe 'Em D0wN!" TRILOGY TwinScrew #209 / TS0019-
  #4
Old 11-13-2017, 10:34 PM
MOTOWN's Avatar
MOTOWN MOTOWN is offline
S/C 20" MINI TUBBED WHEEL GUY!
Trader: (47)
Looks good , A restrictive IC can cause problems when your force feeding 20+psi of boost!
__________________
ITS ALIVE !!!!!!!!
STAY TUNED!!!!!!!!!!
  #5
Old 11-13-2017, 11:15 PM
SGT_MERC's Avatar
SGT_MERC SGT_MERC is offline
Senior Member
Trader: (2)
What offset/backspacing rear wheels did you use? Is the rearend tubbed and suspension work done? What offset/backspacing did you start with on the fronts, before machining?
Sweet setup.....
__________________
SEMPER FI From York, Pa
  #6
Old 11-14-2017, 02:31 AM
BigM460's Avatar
BigM460 BigM460 is offline
Chris Stewart
Trader: (2)
Thumbs up
Nice looking cooler! 6" thick, yikes!
__________________
Chris Stewart
03 Marauder
Paxton 2200
20" wheels
637.21rwhp
538.59rwtq
04 DTR Son's car
4.10, K&N CAI, Jeff tune
Headers, underdrive pulley
297.26 rwhp
312rwtq
06 F-150 Supercrew Lariat 4x4
305/55 20's
  #7
Old 11-14-2017, 04:57 AM
crownvic05 crownvic05 is offline
Senior Member
Trader: (7)
You have a shop in NJ? That's very nice work you did there.
  #8
Old 11-14-2017, 05:24 AM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
Damn nice work Chris! AND bad ass car John!
I REALLY dig the wheels!
Did this clear the bumper mounts? My 4 1/2 Procharger race cooler was a nightmare to fit..
More pics of piping please!
And how about a rear shot of those bald tires you thru on?
__________________
  #9
Old 11-14-2017, 05:47 AM
NorthShoreChiMM's Avatar
NorthShoreChiMM NorthShoreChiMM is offline
Mike
Trader: (0)
Quite Badass
  #10
Old 11-14-2017, 05:53 AM
mm svt mm svt is offline
Senior Member
Trader: (0)
Ive got the sweats, and drool. Love it
  #11
Old 11-14-2017, 08:12 AM
Blown3.8's Avatar
Mr. Hankey
Trader: (2)
Quote:
Sweet setup.....
They are the only sizes they offer in 5x4.50 bolt pattern in 18". Fronts are 2" BS, -25.4 offset. Rears are 7.63" BS 48 offset. No rear end mods just the long ARP studs and diff stuff.
Quote:
I am down in northern VA.
It looks to be able to clear the bumper mounts, may have to notch the lower inside corner of the bumper struts(the thing you made the hole go thru) if you mount like I did. The front edge of cooler sits just behind the header panel lip up top. I went with this one because the specs on treadstones site said 12" tall but its really 12.5 which pushes the bumper cover down just a bit. I also cut the metal brace from behind the IC that connects the frame rails where the bumper struts mount, to facilitate fans.
Johns car came to me without the bumper bars.
__________________
~Chris
  #12
Old 11-14-2017, 08:42 AM
Blown3.8's Avatar
Mr. Hankey
Trader: (2)
A few more pics.
__________________
~Chris
  #13
Old 11-14-2017, 08:48 AM
Blown3.8's Avatar
Mr. Hankey
Trader: (2)
Blow off test video.
https://youtu.be/Cd7lJlEPfOA
__________________
~Chris
  #14
Old 11-14-2017, 09:12 AM
Lowndex's Avatar
Lowndex Lowndex is offline
Middle Age Crisis Member
Trader: (3)
Another Marauder in the 10s. You sir are a bad-ass.
  #15
Old 11-14-2017, 12:05 PM
hotford's Avatar
hotford hotford is offline
hotford
Trader: (3)
Chris didn't this car have a Novi 2200 at one time? looks to have a Vortech unit ...what size...JT-YSI........
__________________
  • 82 GT coyote 6R680 swap started
  • 2000 GT, 04 cobra motor,2.9 Whipple,crusher inlet,built 4r70w trans,04 IRS rear.full weight street car, Corn Fed
  • Best Et 10.03@138 on Drag radials,driven to the track.
  • 2011 GT 500, 3.4 whipple,93 pump gas,10.47@133
    Driven to the track.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Few upgrades Blk04MM Shop Talk 9 10-17-2013 06:34 PM
Looking For Upgrades lancejlove Shop Talk 18 06-16-2013 07:35 AM
JFlave Upgrade Dennis Reinhart Reinhart Automotive 59 08-02-2011 03:14 PM
Powered by: vBulletin
