MercuryMarauder.net Forums
Reply
Thread Tools Display Modes
  #1
Old 11-14-2017, 11:34 AM
Merc390's Avatar
Merc390 Merc390 is offline
Member
Trader: (0)
Engine Builder Search
I know there are a bunch of guys from Illiniois here, so my question to yall is who have you used and liked to trust with engine work. Im a werido and would like a Ford guy to work on my motor. I need to call PER but Id like to have back ups if needed.
The Plan is to bore and stroke the Teksid I have to 5.0, Forge the bottom end, and port polish the heads.
So Any engine builder suggestions are welcomed.
Kyle
  #2
Old 11-14-2017, 12:13 PM
Zack's Avatar
Zack Zack is offline
Turbo Marauder
Trader: (39)
Kyle
FYI any head work does not become beneficial unless: You plan on a radical NA build. Or: you are making north of 800rwhp with boost
  #3
Old 11-14-2017, 01:54 PM
justbob's Avatar
justbob justbob is offline
Sick-Speed play toy
Trader: (11)
http://www.builtriteengine.com
__________________
  #4
Old 11-14-2017, 03:04 PM
Merc390's Avatar
Member
Trader: (0)
Ive heard good and bad stories about them, have you used them personally? It would be ultra convenient for me to use them as Im a couple minutes away.
  #5
Old 11-14-2017, 03:11 PM
Merc390's Avatar
Member
Trader: (0)
Quote:
Even if boost and hotter cams are used?
  #6
Old 11-14-2017, 03:22 PM
stevengerard stevengerard is offline
Senior Member
Trader: (0)
The lead engineer of the engine at Marauderville (11 maybe?) said the heads are the last thing you need to modify. Won't get much out of them until you have done absolutely everything else to the max. 800 RWHP is close to around !000 at the crank, correct? That's a lot of HP, a lot of boost and a lot of other things to work on before you worry about the heads.
__________________
Steven
2004 Marauder Black, loaded
Vortec S/C
4.10s
3500 PI Stall
Kook's headers
476.9 rwhp 385 lbs/tq
Lidio tune
2004 Suburban Dark Charcoal
  #7
Old 11-14-2017, 03:29 PM
Merc390's Avatar
Member
Trader: (0)
I thought get it done when its in the shop to not worry about it, especailly since I have this extra set of heads and the Teskid block.
  #8
Old 11-14-2017, 03:40 PM
RubberCtyRauder's Avatar
Weißbirke Plünderer
Trader: (11)
what is your goal for power and use? porting these heads is not cheap. you have to decide whereto spend ut at..Boost plans, transmission plans, brakes etc. ?
__________________
  #9
Old 11-14-2017, 03:43 PM
justbob's Avatar
Sick-Speed play toy
Trader: (11)
They did my heads three or so years ago and took really good care of me.
__________________
  #10
Old 11-14-2017, 04:03 PM
MOTOWN's Avatar
MOTOWN MOTOWN is offline
S/C 20" MINI TUBBED WHEEL GUY!
Trader: (46)
Your wasting your money stroking to 5.0L nothing to be gained but a lighter wallet , a forged 4.6L will do anything you need it to do HP wise.
__________________
ITS ALIVE !!!!!!!!
STAY TUNED!!!!!!!!!!
  #11
Old 11-14-2017, 04:10 PM
mm svt mm svt is offline
Senior Member
Trader: (0)
If you want your heads ported then have them ported. If you want cams, get cams. If you want arp everything and be conservative on hp don’t worry about what others think it’s your car and your money. The head job you may not notice but but if you decide to go Turbo you can. Stroked crank and a 20 overbore will get your 5.0, from there it’s what ever you want for your teksid block.
  #12
Old 11-14-2017, 04:34 PM
Senior Member
Trader: (0)
^ good point, I like the others are just trying to provide practical information.
__________________
Steven
Vortec S/C
4.10s
3500 PI Stall
Kook's headers
Lidio tune
  #13
Old 11-14-2017, 05:27 PM
Merc390's Avatar
Member
Trader: (0)
Well the block I have needs work on the cylinder walls that’s the only reason why it’ll be bored over, the Heads thing again was a uncertainty.
My main goal at this point is to find a shop I’m comfortable with and that members in the Chicagoland area have either used and are happy with or can recommend me to. I do collision repair so I have everything except the mechanical thing down. My power goal is around 550 to the wheels..
Any knowledge and opinions are fine by me, my thought is a Whipple set up with 10 to 12lb of boost should get me to where I’d like
  #14
Old 11-14-2017, 05:30 PM
Merc390's Avatar
Member
Trader: (0)
Did you deal with Bill?
I’ll drop by him tomorrow to get ideas. May I ask what he charged you for the work?
  #15
Old 11-14-2017, 06:06 PM
Weißbirke Plünderer
Trader: (11)
550 is plenty doable, i almost went that route, didnt want to spend to R&R motor, so i ported my trilogy and did killer chiller with lower pulley swap. You will want plan or,add into the mix a trans upgrade or swap. stock transsl will be short-lived with torquey twin screw.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
engine builder recommends in San Jose area lifespeed West Coast Marauders 54 03-14-2016 05:16 PM
Engine Machine/Builder? O's Fan Rich Sunshine State Marauders 5 11-12-2015 03:58 PM
DOHC Engine Builder in SoCal MarauderPU Shop Talk 8 07-31-2013 03:31 PM
Looking for Mod Motor Engine Builder MarauderPU Shop Talk 4 11-13-2012 01:08 PM
Powered by: vBulletin
