Results 1 to 9 of 9
Thread: Replace rack & pinion?
    Mar 2013
    Maine
    Motor is out, not sure if it's the original or not. Car has 283k on it. Should I replace the unit while the motor is out or are they not that bad when the motor is in? Opinions? How long do these usually last? 03 300A
    If you can grab the inner tie rods and they rattle, then the bushings are worn out, then it is time to swap it out.
    Not a bad job even with the motor in the car, 2-3 hours tops.
    Trilogy # 192 / T.S. 0012
    Nov 2007
    San Jose
    Isn't this a rebuild situation? I don't think the speed-sensitive racks are available new anymore.
    Lifespeed
    Jul 2012
    Seattle Washington
    They last forever.
    Super easy job with the engine in the car.
    No reason to replace it now.
    Mar 2013
    Maine
    Thanks guy, I will ride this out.
    Yes rebuild only life speed.
    Aug 2014
    Bowling Green, KY
    I've been searching for a variable speed rack for a year. You are correct that new ones are not available.
    03 Marauder 300a
    392 hp / 406 tq
    Mar 2013
    Maine
    Aug 2014
    Bowling Green, KY
    Hmm.. Does say hydraulic assist.. But does that mean it's POWER STEERING.. Or Variable? I'd have to see the VAPS unit on the rack to believe it.
    http://www.rockauto.com/en/moreinfo....1387829&jsn=11
    03 Marauder 300a
    392 hp / 406 tq
    Mar 2013
    Maine
    Rock auto had one in stock last week that was a reman and had the VAPS. Its sold out now (as I went to buy it). The same part number is on eBay and available and listed with VAPS...
  1. Rack and pinion ratio?
    By O's Fan Rich in forum Steering, Suspension & Brakes
    Last Post: 12-06-2015, 10:31 AM
  2. Do I need a new Rack and Pinion ??
    By MADRODER in forum Shop Talk
    Last Post: 05-09-2015, 01:45 PM
  3. Rack and Pinion leaking
    By dankwun in forum Shop Talk
    Last Post: 12-14-2012, 11:26 AM
  4. rack and pinion
    By jvillerauder in forum Shop Talk
    Last Post: 04-13-2009, 01:54 PM
  5. Rack & Pinion DOA
    By N40GL in forum Shop Talk
    Last Post: 02-15-2008, 07:44 PM
