Results 1 to 11 of 11
Thread: console??
    May 2004
    Normally Ga.
    Question console??
    Ok, may be a silly question. But how is the overhead console removed? Thanks all.
    2003A Mercury Marauder. Sold it, miss it.
    USMC 06-10-96 to 06-21-06. AH-1W and UH-1N!!!! OORAH!!
    A search 'overhead console removal' yielded the following....
    Quote Originally Posted by FLA RAUD FAN
    This is straight from the service manual:
    For vehicles with the long console with sunglass storage compartment.
    1) Disconnect battery ground cable. ( I did not do this step, did not want to possibly lose my DR PCM flash)
    2) Remove screw at the front of console.
    3) Open sunglass storage compartment and remove two screws.
    4) Disengage the six clip attachments by first pulling down on the front end of the overhead console. ( I used a flat flexible metal putty knife to get started and not damage the fabric) Remove the overhead console.
    * Disconnect the electrical connectors.
    5) To install, reverse the removal procedure.
    For vehicles with roof opening panel
    2) CAUTION: The overhead console bracket is supported by the headliner. Failure to follow the removal procedure will damage the headliner!!
    Support the headliner at the rear corner of the overhead console and pull down on that corner to remove the overhead console.
    3) To, install, reverse the removal procedure.
    For those who need pictures ( Marty , TAF etc. ) !!! HAH. I can e-mail the PDF form that I got from Carfixer
    JP
    The search function really does work!
    2017 Niro
    May 2004
    Normally Ga.
    Talking
    Humm, i said it was a silly question. Thanks.
    Patrick Guest
    Quote Originally Posted by torinodan
    Now you got me curious............... What are we planning Dan? If its not a secret!
    Ive always wanted to modify the overhead console to house about 2-3 gauges facing downward on a slight angle to the drivers seat.
    Might do that this winter.
    May 2004
    Normally Ga.
    Nope, not a secret. All six buttons in my console now have back lighting! After 2 years now, everything seems good considering I can see the things. I used LED strips for ricer type cars from an auto parts store and some 1/8 inch thick plexyglass (that I painfully cut holes in for the buttons) to distribute the glow from the small green lights. I wired into the dimmer circuit that goes from the headlight switch to the compass. They dim as well with instrument panel lights. Alls good and now I can see!!! The following pic is kindof crapy, but it shows all the buttons lit up. I'll show ya on Saturday.
    Quote Originally Posted by Patrick
    Long Island, NY
    Dan - Nice job.
    2003 Marauder 300B,
    Heated Seats
    35% Tint
    Mercury All Weather Mats
    1973 Oldsmobile Toronado
    2012 Kia Sedona Van
    2008 Corvette Convertible
    2021 Prius Prime Limited
    Member # 440
    ----- John
    May 2004
    Normally Ga.
    finished lights
    Ok, thanks to Todd (with a much better camera) I have some better pics of the back lights for the console buttons. This was in daylight and they can be seen very well. Has anyone else got this to work out so far?
    I loved the backlighting. Gotta post a schematic of where you tapped into power for them at least, since you didn't take any pics of the new part as it was being made (before installation).
    Patrick Guest
    Great Dan. Another Mod for my list. I am still planning on the grille work, but my freind has been busy. Thanks.
    Could you email or post how this is done!
    Aug 2003
    Auburn, CA
    Wink
    torinodan - that is a great setup. So far the punching around in the dark to find my garage door opener button has been the most annoying aspect of my MM and you seem to have solved it perfectly: just enough light to find the buttons. Add my voice to the chorus of where did you tap in to do it. And the ricer lights, were they those neon glow type of interior light tubes or something else. I'm asking because, as I tell all new trial attorneys,"Your success in this business is limited only by the creativity of the people whose ideas you steal."
  1. Console removal???
    By Scott Leininger in forum Shop Talk
    Last Post: 05-30-2005, 06:56 AM
  2. Console diagram
    By dwasson in forum Shop Talk
    Last Post: 06-19-2004, 05:22 PM
  3. Overhead Console Removal????
    By schuvwj in forum Shop Talk
    Last Post: 05-12-2004, 04:45 AM
  4. Power outlet in the console...?
    By hitchhiker in forum Community Discussion
    Last Post: 04-06-2004, 08:30 AM
  5. Arm rest console stash spot
    By CRUZTAKER in forum Community Discussion
    Last Post: 07-03-2003, 03:30 AM
